Multilayer perceptron support
nikos1
Valued Contributor I
In one of our applications we need to execute MLP inference.  Is this a supported OpenVino network or just CNNs are supported? We have a frozen tensorflow model but fails to go through the model optimizer.
Severine_H_Intel
Hi Nikos,
As a MLP network is a network with fully connected layers and ReLU activations, therefore we should support it. OpenVINO can do more than just CNN. Can you describe here the error you are facing when importing from TF?
Best,
Severine
Severine_H_Intel
Hi Nikos,
Best,
Severine
nikos1
Hi Severine,
Thank you  for confirming MLP support in OpenVino.  MLP model optimization process works fine now.
JFTR the issue was that tf.float64 was used for weights/biases causing the following error below. Changing to the default TF dtype tf.float32 , retraining and model optimization worked fine.
[ ERROR ] Cannot convert type of placeholder "x" because not all of its outputs are "Cast" to float operations: ['MatMul'].
For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_tools/documentation/docs/MO_FAQ.html), question #49.
Nikos
