6594 Discussions
How to add a new Solr Slave in AWS Bitnami certified Solr
I have a 1 Master with 1 Slave Solr cluster in AWS. This is the Bitnami version of Solr. How do I go about adding a second Slave to this existing cluster?
In a regular Solr setup I would just fire off a new server, install Solr and change config to add the new instance but I'm not sure how to do this with the Bitnami setup as there seems to be some differences how it is setup from out-of-the-box Solr.
