Myraid compile blob file creation issue
Elakkiya
Hi, I have the .bin and .xml files of a custom trained SSD model. Im trying to compile the blob files using the following command but it returns STOI and doest create a blob file as expected.
I would like to understand this behaviour
myriad_compile -m <saved_model.xml>  -ip U8 -VPU_NUMBER_OF_SHAVES 4 -VPU_NUMBER_OF_CMX_SLICES 4
Inference Engine:
	API version ............ 2.1
	Build .................. 2021.1.0-1237-bece22ac675-releases/2021/1
	Description ....... API
stoi
System information (version)
  • OpenVINO: intel-openvino-runtime-ubuntu20-2021.1.110
  • Operating System / Platform:Ubuntu20.04
  • Problem classification:Model Conversion
  • Model name: ssd_mobilenet_v2_320x320_coco17_tpu-8 (TF2 Model Zoo)
IntelSupport
Community Manager
Hi Elakkiya,
Thanks for reaching out.Did your model is the same from here?
http://download.tensorflow.org/models/object_detection/tf2/20200711/ssd_mobilenet_v2_320x320_coco17_tpu-8.tar.gz
Can I know how you generate the .xml and .bin files? Did these files execute from OpenVINO Model Optimizer? If so, please share the command so that we can reproduce the same workaround.
Meanwhile, you could try converting using compile_tool.exe and see if an input blob can be created. You need to add a parameter -d MYRIAD when using the compile_tool.exe. You can find more information regarding the compile tool from the following page.
https://docs.openvinotoolkit.org/latest/openvino_inference_engine_tools_compile_tool_README.html
Aznie
IntelSupport
Community Manager
Hi Elakkiya,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
