NCS2 Restart
Ramirez__David
I am working with openvino 2020.2.120, the NCS2 and python API, The program loop runs fine the first time however, each time I stop the program and start it again, I have to unplug and plug again the NCS2 because if I don't do that, it shows an error:
Can not init Myriad device: NC_ERROR
Is there a way to close or clear the device before exiting the program, or restarting it before the program executes again?
-David
SIRIGIRI_V_Intel
The issue seems to be the NCS2 is being used by the program. Can you try to run the object_detection_demo_ssd_async sample on the NCS2 and let us know the behavior.
Ram prasad
Ramirez__David
Thanks for the response
The issue seemed to be related to using jupyter notebooks: running, stopping and re-running a cell, caused the error; however, the same code in a .py file ran correctly when stopped and ran afain
