NCS2 had problems with jetson nano
jevons
Hello, everyone.
I downloaded the DLDT library of opencv on jetson nano. After the successful compilation and installation, I prepared to run my demo, but it reported the following error. I hope you can help me solve it.
/home/zhu/test/emotion_infer.py:32: DeprecationWarning: from_ir() method of IENetwork is deprecated. Please use IENetwork class constructor to create valid IENetwork instance
  self.net = IENetwork.from_ir(model=self.model_xml_path, weights=self.model_bin_path)
E: [ncAPI] [    616244] [python3] ncDeviceOpen:859      Device doesn't appear after boot
Traceback (most recent call last):
  File "emotion_infer_demo.py", line 1, in <module>
    from emotion_infer import detect
  File "/home/zhu/test/emotion_infer.py", line 119, in <module>
    emotion_detect = emotionInfer()
  File "/home/zhu/test/emotion_infer.py", line 33, in __init__
    self.exec_net = self.plugin.load(network=self.net)
  File "ie_api.pyx", line 547, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 557, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Can not init Myriad device: NC_ERROR
regrads
JesusE_Intel
Hi jevons,
It looks like the Intel(r) Neural Compute Stick 2 is not connecting properly when the model is loaded. Did you configure the Intel(r) NCS 2 Linux USB Driver? If you have not, please use the following steps.
1. Add the current user to the users group, you will need to logout and log back in.
sudo usermod –a –G users “$(whoami)”
2. Create 97-myriad-usbboot.rules in the /etc/udev/rules.d directory with the following content:
SUBSYSTEM=="usb", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="2485", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="f63b", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
3. Reload the rules
udevadm control --reload-rules
udevadm trigger
ldconfig
I don't have a Jetson Nano to test, however, it worked on the Jetson TX2 that I have. Please let me know if it works for you.
Jesus
JesusE_Intel
Hi jevons,
3. Reload the rules
udevadm trigger
ldconfig
Jesus
jevons
Hello Jesus
Your solution has solved my problem perfectly and the nano is now running normally. Thank you for your answer.
Regrads
JesusE_Intel
Hi jevons,
Great! Thanks for letting me know.
Jesus
