6594 Discussions
NCS2 not detected when running python samples
skrywenko
hi there . I have being trying to get this  ncs2 usb stick to work  in python with ubuntu 20.04(LTs) and 22.04 (LTS) all on fresh installs openvino==2022.3.2 & openvino-dev==2022.3.2 and it always the same. no MYRIAD. when using any of the sample openvino_runtime   or in any of open_model_zoo-2022.3  version.. when I run a cpp version software it works fine  just not any python code.  I even tried recompiling code from source  it seams the same thing
Peh_Intel
Hi skrywenko,
OpenVINO™ Runtime package install from PyPI only includes a set of libraries for Intel® CPU and Intel® GPU hardware.
To use MYRIAD plugin, please install OpenVINO™ Runtime from an archive file (https://storage.openvinotoolkit.org/repositories/openvino/packages/2022.3.1/linux/
) For OpenVINO version 2022.3.1, the archive file is only available for Ubuntu 18 and Ubuntu 20.
Once you have OpenVINO™ Runtime installed, follow the steps in Configurations for Intel® Neural Compute Stick 2 to be able to work on NCS2.
Peh
skrywenko
well i do not know  - I got python to work from my original install of 2022.3.2. but it just started to work out of the blue after I gave up for a couple days.  was doing facial recognition  and that. did a simple reboot. now  myriad is un detectable  across all platforms that i rebooted. only detectable with the source compiled version.  the downloaded versions all stopped working and only cpu is see able.  no more gna or myriad. when running benchmark_app -h -- very frustrating device that is for sure. no wonder intel stopped making them. if they were always this frustrating..
Peh_Intel
Hi skrywenko,
1)    Download OpenVINO™ Runtime from the archive file below on Ubuntu 20.04.
l_openvino_toolkit_ubuntu20_2022.3.2.9279.e2c7e4d7b4d_x86_64.tgz
2)    Extract all the files from the archive file.
3)    Update several environment variables by running the setupvars.sh script to use MYRIAD libraries.
source setupvars.sh
4)    Run benchmark_app -h command.
Peh
Peh_Intel
Hi skrywenko,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
