Does the NCS2 work with the Multi Camera Multi Target python demo?
I run it but get the error:
RuntimeError: [ GENERAL_ERROR ]
C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\inference-engine\src\vpu\graph_transformer\src\frontend\frontend.cpp:439 Failed to compile layer "736": [ GENERAL_ERROR ]
C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\inference-engine\src\vpu\graph_transformer\src\stages\mvn.cpp:94 Unsupported combination of indices in layer "736". Only across channel and full batch supported.
Works if I do not include the -d MYRIAD argument.
Hi Duggy,
Thank you for reaching out to us and thank you for using Intel® Neural Compute Stick 2!
For your information, Multi Camera Multi Target Python Demo expects the following models in the Intermediate Representation (IR) format:
· object detection model or object instance segmentation model
· object re-identification model
List of supported models for this demo and the details on model’s inference support at different devices are shown as follow:
Model Name |
CPU |
GPU |
MYRIAD |
instance-segmentation-security-0002 |
YES |
instance-segmentation-security-0091 |
YES |
instance-segmentation-security-0228 |
YES |
instance-segmentation-security-1039 |
YES |
instance-segmentation-security-1040 |
YES |
person-detection-retail-0013 |
YES |
YES |
YES |
person-reidentification-retail-0277 |
YES |
YES |
person-reidentification-retail-0286 |
YES |
YES |
person-reidentification-retail-0287 |
YES |
YES |
person-reidentification-retail-0288 |
YES |
YES |
vehicle-reid-0001 |
YES |
YES |
YES |
We regret to inform you that object re-identification models are not supported by MYRIAD Plugin. Hence, it is expected to encounter errors when running the demo application using Intel® Neural Compute Stick 2.
Hope it helps.
Wan
Hi Duggy,
Thanks for your question.
This thread will no longer be monitored since we have provided explanations.
If you need any additional information from Intel, please submit a new question.
Wan
