6574 Discussions
NCS2 with Multi Camera Multi Target Python fails
Duggy
Does the NCS2 work with the Multi Camera Multi Target python demo?
I run it but get the error:
RuntimeError: [ GENERAL_ERROR ]
C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\inference-engine\src\vpu\graph_transformer\src\frontend\frontend.cpp:439 Failed to compile layer "736": [ GENERAL_ERROR ]
C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\inference-engine\src\vpu\graph_transformer\src\stages\mvn.cpp:94 Unsupported combination of indices in layer "736". Only across channel and full batch supported.
Works if I do not include the -d MYRIAD argument.
Labels (3)
Wan_Intel
Hi Duggy,
Thank you for reaching out to us and thank you for using Intel® Neural Compute Stick 2!
For your information, Multi Camera Multi Target Python Demo expects the following models in the Intermediate Representation (IR) format:
·      object detection model or object instance segmentation model
·      object re-identification model
List of supported models for this demo and the details on model’s inference support at different devices are shown as follow:
Model Name
CPU
GPU
MYRIAD
instance-segmentation-security-0002
YES
instance-segmentation-security-0091
YES
instance-segmentation-security-0228
YES
instance-segmentation-security-1039
YES
instance-segmentation-security-1040
YES
person-detection-retail-0013
YES
YES
YES
person-reidentification-retail-0277
YES
YES
person-reidentification-retail-0286
YES
YES
person-reidentification-retail-0287
YES
YES
person-reidentification-retail-0288
YES
YES
vehicle-reid-0001
YES
YES
YES
We regret to inform you that object re-identification models are not supported by MYRIAD Plugin. Hence, it is expected to encounter errors when running the demo application using Intel® Neural Compute Stick 2.
Hope it helps.
Wan
Wan_Intel
Hi Duggy,
Thanks for your question.
This thread will no longer be monitored since we have provided explanations.
If you need any additional information from Intel, please submit a new question.
Wan
