I am Using NanoPi-m4 with SoC: Rockchip RK3399
CPU: big.LITTLE,Dual-Core Cortex-A72(up to 2.0GHz) + Quad-Core Cortex-A53(up to 1.5GHz)
GPU: Mali-T864 GPU,supports OpenGL ES1.1/2.0/3.0/3.1, OpenVG1.1, OpenCL, DX11, and AFBC
VPU: 4K VP9 and 4K 10bits H265/H264 60fps decoding, Dual VOP, etc
with FriendlyDesktop (Ubuntu core) 18.04 64
architecture: arm (aarch64)
I have issues in installing ncsdk2 latest version v2.10.
ERROR: opt/movidius/ncsdk/aarch64/tk no such file or directory.
I used this repository https://github.com/markjay4k/ncsdk-aarch64 to install ncsdk but it was version 1.12 it worked well but when I modified it to install version 2.10 it had issues in shared libraries
Is there an incompatibility between ncsdk2 and nanopi?
Hi @Ahmed_Gaber
We have not validated the NanoPi-m4 with the Neural Compute SDK 1 or 2. The repository above modified the installation for the NCSDK 1, I am not familiar with the changes made.
Currently we only support X86 and Raspberry Pi 3+ running Raspbian.
Please share your results with the community if you get a successful install.
Jesus
