6574 Discussions
NCSDK 2.10 mvNCCompile Segmentation Fault
I have a lot of experience with NCS and NCSDK. I have now upgraded to NCSDK 2.10. Installation worked fine. However when I run "make examples" or try to compile any other blob with mvNCCompile I get:
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Segmentation fault (core dumped)
I have Ubuntu 16 and NCSDK 2.08 worked fine.
Thanks for your help!
Hi @mumes
Could you share the Caffe model used to compile on the NCSDK 2.08 and 2.10? I tried to compile this Caffe model and did not see a Segmentation fault.
Jesus
