NCSSDK run AlexNet example error
1. device
unbutu 16.04 NCS
2.command
action@action:~/code/ncs/ncsdk/examples/caffe/AlexNet$ make run
3.information
`\nmaking prereqs
(cd ../../data/ilsvrc12; make)
make[1]: Entering directory '/home/action/code/ncs/ncsdk/examples/data/ilsvrc12'
make[1]: Leaving directory '/home/action/code/ncs/ncsdk/examples/data/ilsvrc12'
chmod +x run.py
\nmaking prototxt
Prototxt file already exists
\nmaking caffemodel
caffemodel file already exists
\nmaking compile
mvNCCompile -w bvlc_alexnet.caffemodel -s 12 deploy.prototxt
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:46: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(False, "Layer type not supported by Convolution: " + obj.type)
/usr/local/bin/ncsdk/Controllers/Parsers/Phases.py:322: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(len(pred) == 1, "Slice not supported to have >1 predecessors")
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
Fusing Pad and Convolution2D
Fusing BatchNorm and Scale after Convolution
Replacing BN with Bias&Scale
Fusing Permute and Flatten
Fusing Eltwise and Relu
Eliminate layers that have been parsed as NoOp
Evaluating input and weigths for each hw layer
Network Input tensors ['data#24']
Network Output tensors ['prob#38']
Blob generated
\nmaking run
./run.py
E: [ 0] dispatcherEventSend:820 Write failed -7
E: [ 0] dispatcherEventReceive:236 dispatcherEventReceive() Read failed -4
E: [ 0] eventReader:254 Failed to receive event, the device may have reset
E: [ 0] dispatcherEventSend:811 Write failed -4`
Hi @yangxiu123321
Are you using the Neural Compute Stick (NCS) 1 or 2?
Can you provide the output of lsusb?
Jesus
