6605 Discussions
How to pre-train a model to be used with my own live data?
Warren__Matt
Please pardon the triviality of my question, as I am new to Computer Vision and AI.
I was wondering how to use my existing database of plant photos to create a pre-trained model that I can use against live input (plant photos), to get the inference/ouput?
Any help/tips would be greatly appreciated!
Thank you!
Matt
nikos1
Valued Contributor I
Hello Matt,
After you have a Tensorflow model the next step would be to generate valid IR (bin and xml files) that OpenVino can use
Please refer to https://software.intel.com/en-us/articles/OpenVINO-ModelOptimizer on more details how to use the model optimizer.
Inference Engine enables deploying your network model trained with any of supported deep learning frameworks: Caffe*, TensorFlow*, MXNet*, Kaldi*, or converted to the ONNX* format. To perform the inference, the Inference Engine does not operate with the original model, but with its Intermediate Representation (IR), which is optimized for execution on end-point target devices. To generate an IR for your trained model, the Model Optimizer tool is used.
A good start with OpenVino is also to build and run the samples as they demonstrate the whole workflow.
Cheers,
Nikos
whatthisismyname
TIPS:
1- Wrong Forum
2-You need to find a framework and suites you
3-Learn how to use it
4-Make sure its compatible with NCS
5-Train your model
6-Convert it to OpenVINO format
7-Build your code  and be happy :)
Warren__Matt
Hello Daniel,
Thank you for the tips. I am hoping you can enlighten me:
1. If this is the wrong forum for learning how to use OpenVino, can you point me to the correct forum?
2. I am not sure what "You need to find a framework and suites you" means? I have built a Python script utilizing Tensorflow for my CNN algorithm(s) and I am getting decent accuracy - how do I translate that to something that can be consumed by the OpenVino Model Optimizer?
Thank you for your time!
Matt
nikos1
Hello Matt,
Cheers,
Nikos
Warren__Matt
Hello Nikos,
Thank you so much for this information. This bridges a major gap for me. I have my script, I have my data for training, I just don't know how to get this stuff into a (*.pb?) format for optimizing - the info you shared is a great start for me. Thank you.
As for starting with OpenVino, I have completed the 2 provided demos, but maybe I treated them as a black box. I will dig further into the contents.
Thank you again.
Matt
nikos1
Hi Matt,
I typically freeze Tensoflow models (please search how to freeze to pb) but it seems OpenVino can also work with not frozen models as shown in section "Load Non-Frozen Models to the Model Optimizer"  of
https://software.intel.com/en-us/articles/OpenVINO-Using-TensorFlow
nikos
Gdeep
Dear Warren
Please Follow this tutorial to train your tensorflow model on the custom object detection
https://tensorflow-object-detection-api-tutorial.readthedocs.io/en/latest/training.html
Warren__Matt
Hello Nikos and Gagan,
Firstly, thank you very much for taking the time to help me.
Secondly, I am going to proceed with these beginning steps and follow up.
Thank you very much, again.
-Matt
whatthisismyname
I guess you got your answer but you were on step #5 so yes, just converted the data and use it with openVINO sdk :)
