6605 Discussions
Need Help to run Intel Neural Computer Stick 2?
Bbill14
Hello everyone I'm New here, and I hope someone can help me.
I have bought recently a intel NCS-2, and have start by the getting started demo for Linux and Raspbian and have finished successfully. Now, I need a detailed example or tutoriel (simple one) on how to build a neural network and run it in the NCS-2.
Thank you.
MAURICIOAL_R_Intel
Hello Bbill14,
Thank you for contacting Intel customer support. In this case we are going to do some research about your question, and come back to you with an answer as soon as possible.
Mauricio R.
Intel Customer Support Technician
A Contingent Worker at Intel.
Bbill14
Hello Mauricio.
Thank you for your response.
Any help will be appreciated.
Regards.
MAURICIOAL_R_Intel
Hello Bbill14,
We recommend you to look at our pre-build samples/demos at:
https://github.com/opencv/open_model_zoo/tree/master/demos
https://docs.openvinotoolkit.org/latest/_tools_downloader_README.html
Also, if you want to build your own custom model, you can use one of the supported topologies as a base model. You can see the list here.
Additionally, you can check the guide on building a custom object detection model.
Please let me know if you have additional questions.
Mauricio R.
Bbill14
Hi Mauricio
I have try to see the examples that you have send it to me, but I'm still confused.
For exemple: If I have my model in h5 file or json file, what should I do to run it in the NCS2?
MAURICIOAL_R_Intel
Hello Bbill14,
You need to use the model optimizer to convert to IR files. Also, for the Keras model (.h5), you can check this thread for more information about this model.
Additionally, we recommend you looking at the supported models for MYRIAD (NCS).
Mauricio R.
