How to install on macOS
Thibault__Pierre
If I go to Get Started with Intel® Neural Compute Stick 2, I cannot find the instructions for installing on macOS. But I can download the installer at https://software.intel.com/en-us/openvino-toolkit/choose-download/free-download-macos. And then when I open the installer application, I have a message saying that the application is potentially a malware and that I have to contact the developer of the application. I cannot start the installer. Can you help me install OpenVino on macOS Catalina?
Thibault__Pierre
And I am also unable to download the installer using Firefox. I have to use Chrome. Otherwise, the download page does not display properly.
Thibault__Pierre
I found that I can start the installer application if I use the Open command from the contextual menu. This is solving my issue.
Thibault__Pierre
I talked too fast. The installer says  the operating system is not supported. I says it needs version 10.13 while I have version 10.15. So I cannot install.
David_C_Intel
Hello Pierre,
Thank you for reaching out.
Please try following this guide to install the OpenVINO™ toolkit for MacOS, you will find everything you need there.
If you have any additional questions feel free to contact us again.
David
Thibault__Pierre
The registration page https://software.seek.intel.com/openvino-toolkit?os=macos is broken on Firefox. I have to use Chrome. Then the software does not install on macOS Catalina 10.15. It needs to be updated.
David_C_Intel
Hi Pierre,
Thank you for your reply.
We have reported the issue to the developers. In the meantime, you can take a look at the following Apple guide and choose to run the application.
If you need more help, I will be happy to help you.
David
David_C_Intel
Hello Pierre,
Unfortunately, OpenVINO™ toolkit is not currently supported on MacOS Catalina. To suppress the warning and continue with the install use shift + right click and select open.
David
