No Support for Tensorflow/GRU?
mckittrick
I'd like to convert an existing model with OpenVINO for a CV application, but it appears that a very common layer, GRU, is not supported for Tensorflow?  Based on what I'm seeing here:  https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Supported_Frameworks_Layers.html#onnx_supported_operators
I'm surprised that such a common layer that has been in use for some time with TF is not supported?  Is there any workaround?
Iffa_Intel
Greetings,
Generally, Openvino does support GRU, you can refer here:
https://docs.openvinotoolkit.org/latest/openvino_docs_ops_opset.html
https://docs.openvinotoolkit.org/latest/openvino_docs_ops_sequence_GRUCell_3.html
However, it varies according to which model you are using. For instance as the link you shared, ONNX model is not supported
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
