6592 Discussions
Exception occurred during running replacer "REPLACEMENT_ID"/TF BiT model conversion
armantaposh
I have issues while converting  TF2 BiT model downloaded from tensorflow hub to IR files. Tensorflow frozen graphs seems to be working fine but BiT model directly downloaded from tf hub comes with saved model .pb file and variables and asset folder.
Below is my environment:
OS: Both Windows 10 and Ubuntu 20
Python Version : 3.8
TF version : 2.0
Openvino Version : openvino_2021.1.110
I am adding the log file here.
Iffa_Intel
Greetings,
Please help to cross check whether your model/topology is supported by Openvino: https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Only the listed are supported.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
