6587 Discussions
Not able to install ncsdk inside a smart camera running on ARM!!!
root@NUERA-Demo:~/ncsdk# make install
./uninstall-opencv.sh
__________ Please confirm ____________*
NCSDK 1.11 requires that previous installations of openCV
be uninstalled before proceeding with NCSDK installation.
Note that if you installed opencv via pip3 or from source into the
home directory, it will be uninstalled.
Continue uninstalling OpenCV (y/n) ? y
OpenCV already setup for python
Uninstalling opencv pip installation
sudo: pip3: command not found
Looking for opencv source installation
\nmake install starting.
./install.sh
Connecting to downloadmirror.intel.com (72.246.232.9:443)
wget: server returned error: HTTP/1.1 502 Connection reset by peer
cp: cannot stat 'NCSDK-1.12.01.01.tar.gz': No such file or directory
tar (child): ./ncsdk.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
mv: cannot stat 'NCSDK-1.12.01.01*': No such file or directory
./install.sh: line 40: cd: /opt/movidius/NCSDK: No such file or directory
./install.sh: line 47: ./install-ncsdk.sh: No such file or directory
rm: cannot remove 'ncsdk.tar.gz': No such file or directory
Hi @Dharani ,
Thanks for reaching out. As the NCSDK documentation states here https://movidius.github.io/ncsdk/install.html only x86-64 with Ubuntu (64 bit) 16.04 Desktop and Raspberry Pi 3 with Raspbian Stretch (starting with SDK 1.09.xx) are supported. There have been users who have tried and installed the NCSDK on non-supported architectures like on this thread https://ncsforum.movidius.com/discussion/380/how-to-install-the-ncsdk-on-an-armv8-linux-kernel-ubuntu-rootfs-aarch64-but-not-rpi. May I ask which board are you trying to install the NCSDK on? Are you using the NCS1 or NCS2?
@Luis_at_Intel
