6597 Discussions
Not able to use dynamic batching on mask rcnn model
Ramasabarinathan
         I referred https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_DynamicBatching.html and trying to implement the dynamic batching with the /intel/openvino/deployment_tools/open_model_zoo/models/public/mask_rcnn_inception_v2_coco. I have converted the model into IR and used to implement the dynamic batching. But when loading the network in python using (ie.load_network(network=net, device_name=device, num_requests=num_reqs)), it ends in error as below.
exec_net = ie.load_network(network=net, device_name=device, num_requests=num_reqs)
File "ie_api.pyx", line 336, in openvino.inference_engine.ie_api.IECore.load_network
File "ie_api.pyx", line 345, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: MKLDNNGraph::CreateGraph: such topology cannot be compiled for dynamic batch!
But the same code is working in Image classification models like GoogleNet, AlexNet but i need to use the mask rccn model.
Please let me know how to make the mask rcnn model to work with dynamic batching.
IntelSupport
Community Manager
Hi Ramasabarinathan,
Thanks for reaching out.
According to your error, I suspect your model must have unsupported layers by the dynamic batching feature. Check out the list of supported layers from this documentation:
If possible, you could share your model for us to verify and have a better view regarding this.
Aznie
Ramasabarinathan
Hello Aznie,
    Thanks for checking on this. Please find the attached model and it is converted from intel distribution under  /intel/openvino/deployment_tools/open_model_zoo/models/public/mask_rcnn_inception_v2_coco
IntelSupport
Community Manager
As I see, ReLU is not one of the supported layers by dynamic batching features referring to the documentation that I have provided before. This might be the reason for the error.
Aznie
Syamimi_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Syamimi
