6597 Discussions
OPEN VINO: MKLDNNPlugin error during execution of security_barrier_camera_sample.exe
Bansal__Krishan
Hi ,
when i was running a demo example from demo_security_barrier_camera.bat then during inference engine security , I see below error:
[ ERROR ] Cannot find plugin to use :Tried load plugin : MKLDNNPlugin,  error: Plugin MKLDNNPlugin cannot be loaded: cannot load plugin: MKLDNNPlugin from ../../../lib/intel64: Cannot load library '../../../lib/intel64\MKLDNNPlugin.dll': 126 from cwd: C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\inference_engine\bin\intel64\Release, skipping
cannot load plugin: MKLDNNPlugin from : Cannot load library 'MKLDNNPlugin.dll': 126 from cwd: C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\inference_engine\bin\intel64\Release, skipping
Where as I see MKLDNNPlugin.dll present at the directories mentioned.
Run command generated was as per below:
###############|| Run Inference Engine security barrier camera sample ||###############
Waiting for 0 seconds, press a key to continue ...
security_barrier_camera_sample.exe -i "C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\demo\\..\demo\car_1.bmp" -m "C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\demo\\..\intel_models\vehicle-license-plate-detection-barrier-0007\FP32\vehicle-license-plate-detection-barrier-0007.xml" -m_va "C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\demo\\..\intel_models\vehicle-attributes-recognition-barrier-0039\FP32\vehicle-attributes-recognition-barrier-0039.xml" -m_lpr "C:\Intel\computer_vision_sdk_2018.2.317\deployment_tools\demo\\..\intel_models\license-plate-recognition-barrier-0001\FP32\license-plate-recognition-barrier-0001.xml" -d CPU -d_va CPU -d_lpr CPU
InferenceEngin
Severine_H_Intel
Hi Krishan,
what is your CPU? Are you running this demo on Windows 10?
Can you run the problematic command line alone and copy here the debug output?
Best,
Severine
Bansal__Krishan
Hi Habert,
The issue was resolved after i re-installed openVino in repair mode.
Krishan Bansal
yu__xiaolong
hello ,i get the same error ,and i do re-installed openVino in repair mode , but it still in error:
[ ERROR ] Cannot find plugin to use :Tried load plugin : MKLDNNPlugin,  error: Plugin MKLDNNPlugin cannot be loaded: cannot load plugin: MKLDNNPlugin from ../../../lib/intel64: Cannot load library '../../../lib/intel64\MKLDNNPlugin.dll': 126 from cwd: D:\Intel\computer_vision_sdk_2018.4.420\deployment_tools\inference_engine\samples\security_barrier_camera_demo, skipping
cannot load plugin: MKLDNNPlugin from : Cannot load library 'MKLDNNPlugin.dll': 126 from cwd: D:\Intel\computer_vision_sdk_2018.4.420\deployment_tools\inference_engine\samples\security_barrier_camera_demo, skipping
my CPU is i7-7500u
Wang__Yumeng
Hi, I got the save error: RuntimeError: Cannot find plugin to use :Tried load plugin : MKLDNNPlugin, error: Plugin MKLDNNPlugin cannot be loaded: cannot load plugin: MKLDNNPlugin from : Cannot load library 'MKLDNNPlugin.dll': 126 from cwd: C:\Users\Devymex\source\repos\easyinfer\samples\resnet, skipping
Shubha_R_Intel
Dear folks,
this is an extremely old forum thread. Have you tried with OpenVino 2019 R1 ? If not, I strongly encourage you to install it and try again.
Thanks for using OpenVino !
Shubha
