OPENVINO hello_query_device error
Asif_S_Intel
직원
1,254 조회수
I run lxc container with rootfs as ubuntu-base-18.04-base-i386.tar.gz and copy dldt inside the rootfs. While running hello_query_device I'm getting error.
Please find the attachment.
Note: I have run the above mentioned scenarios with different ubuntu rootfs successfully in the past and set correct path (LD_LIBRARY_PATH) as well.
0 포인트
1 응답
JesusE_Intel
중재자
1,254 조회수
Hi Asif,
I have not tried using OpenVINO inside a container, however, it looks like you are using the opened-sourced version of OpenVINO. Did you install all the dependencies? Additionally, there is a discussion on the Github repository about a similar issue.
Hope this helps!
Jesus
0 포인트
응답
