OPen device failed rc=-7
I am using an ARM7 platform and trying to connect to the usb stick.
dmesg shows
[ 16.245656] usb 1-1: new high-speed USB device number 2 using xhci-hcd
cat /sys/kernel/debug/usb/devices shows the the device is identified by the kernel. shows
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=03e7 ProdID=2150 Rev= 0.01
S: Manufacturer=Movidius Ltd.
S: Product=Movidius MA2X5X
S: SerialNumber=03e72150
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=11 Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
When running "./ncs_check -1" I get
"OpenDevice 1 failed, rc=-7"
Form the header file "mvnc.h" it looks the boot file was not found.
The boot file is in "MvNCAPI.mvcmd" ( Think this is the one) is placed in /usr/local/lib/mvnc
What might be the reason for the failure ?
Yair
After building a 32-bit version of libmvnc on Ubuntu 16.04, I get the exact same error:
/opt/movidius/NCSDK/tests/api-check/ncs-check -1
OpenDevice 4 failed, rc=-7
The error comes from ncs-c-check.c:139
I also have MvNCAPI.mvcmd in /usr/local/lib/mvnc.
Nathaniel
@nathanielchen,
Looks like you are trying to run ncs-check manually. The error is thrown by the ncs-check app because mvncOpenDevice filed, which most probably is because of a libusb-1.0-0-dev issue. Please make sure all dependencies are installed on your system. I have listed the platform and python dependencies in https://movidius.github.io/blog/ncs-apps-on-rpi/.
I have been able to port the API on ARMv6, ARMv7 and ARMv8 architectures by following the instructions on https://movidius.github.io/blog/ncs-apps-on-rpi/.
