6584 Discussions
OpenCV (4.1.2-openvino) Unsupported Extension Error - Solved
Chetan_V_Intel
                      I am using OpenCV(4.1.2-openvino) , when I am trying to write video output I am getting below error. Although my output video is still getting generated. Below is cv2.VideoWriter statement and full error signature. Please let me know how to resolve this.
out_video=cv2.VideoWriter(out_video_name,cv2.VideoWriter_fourcc('M','J','P','G'), fps, (frame_width,frame_height))
Error signature :
MFX: Unsupported extension: .\test_images\test_video.avi
MFX: Unsupported FourCC: MJPG (0x47504a4d)
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\build\opencv\modules\videoio\src\cap.cpp (392) cv::VideoWriter::open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.1.2-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\build\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file): .\test_images\kid_family_in_car_out.avi in function 'cv::icvExtractPattern'
Chetan
Max_L_Intel
Khan, N Maajid (Intel) wrote:
I am also getting the same error
MFX: Unsupported extension: Safety_Full_Hat_and_Vest.mp4
[ WARN:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.2\build\windows\opencv\modules\videoio\src\cap_msmf.cpp (681) CvCapture_MSMF::initStream Failed to set mediaType (stream 0, (0x0 @ 1) MFVideoFormat_RGB32(unsupported media type)
To close the application, press 'CTRL+C' here or switch to the output window and press ESC key
Hello all.
This problem in OpenVINO 2020.2 release being considered as a bug. Problem is related to media files with audio streams and MSMF backend.
Meanwhile, you can use one of the following workarounds:
1. Install FFmpeg as VideoCapture backend (on Windows you need to download OpenCV community plugin. There's downloader script in the package: openvino\opencv\ffmpeg-download.ps1. Right click on it - Run with PowerShell).
2. Use hot fix available in upstream https://github.com/opencv/opencv/pull/17406
3. Use media file without audio stream
Maksim_S_Intel
This is internal error message, it can be ignored. To suppress it you can set videoio backend explicitly: VideoWriter(filename, cv2.CAP_OPENCV_MJPEG, ...).
chew__minjian
Hi, I am having the same error, but the output video is not generated. Please help, thx.
chew.
chew__minjian
Hi, I have realised my mistake and solved it. Thank you.
Chew.
中国
您好,我遇到了同样的问题。你是怎么解决的
Luis_at_Intel
Hi chew, minjian,
Glad you were able to resolve the issue. I'd be great to know what the problem was and how you managed to resolve it, so other community members can benefit from it in case they run into something similar. Thanks for using OpenVINO!
Luis
Arkhipov__Vitaly
Looks like I have the same issue: " MFX: Unsupported extension: http://<ip_address>"
Please what setting I have to make if I use python code :
net = cv2.dnn.readNetFromCaffe(prototxt, model) # specify the target device as the Myriad processor on the NCS if DNN_TARGET_MYRIAD: net.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)
_frame = cv2.resize(frame, (DIMENSION_X, DIMENSION_Y))
blob = cv2.dnn.blobFromImage(_frame, 0.007843, (DIMENSION_X, DIMENSION_Y), (127.5,127.5,127.5), True)
detections = net.forward()
I use cv2.version = '4.2.0-openvino'
Segura__Jaime
I have a similar problem... but... my code actually works perfect on python.
The problem is reported only on the EXE (one standalone file) created with pyinstaller for distribution.
The segment of my code is:     ( / is used because I have pathlib paths)
fourcc = cv2.VideoWriter_fourcc(*'XVID')
frame = cv2.imread(str(exampath / (images_foto[0])))
height, width, layers = frame.shape
a=input('Pause... before the error')
video = cv2.VideoWriter('D:/pruebaOTRO.avi', fourcc, 24, (width,height))
a=input('Pause... after the error')
for image in images_foto:
    video.write(cv2.imread(str(exampath / image)))
and the problem reported between "pauses" is:
[ERROR:0] global C:\projects\opencv-python\opencv\modules\videoio\src\cap.cpp (415) cv::VideoWriter::open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.2.0) C:\projects\opencv-python\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file): D:/pruebaOTRO.avi in function 'cv::icvExtractPattern'
I don't understand where or WHY is the problem
Jain__Nikhil
I AM USING  CPP EXECUTABLE FILE
NMaajid_K_Intel
Lin__Moda
Hi Nikhil & Maajid,
This is a problem with the Ver 2020.2.
It is normal to change to the Ver 2020.1.
This problem has troubled me for a while......
ryanyousong
OpenCV(4.3.0-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\2020.2\build\windows\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file): car.jpg in function 'cv::icvExtractPattern'
please help
thankyou
Tchouanga__Franck
please
Lin, Moda
  you solved the mfx extension problem just by changing version
Max_L_Intel
Hello all.
Tchouanga__Franck
please how do we undergo the first step
Max_L_Intel
Hi Franck.
You can use just one of these 3 workarounds suggested. This is needed if you experience this "MFX: Unsupported extension" error in Windows OpenVINO 2020.2 and 2020.3 versions.
For the first one, as mentioned, there is a downloader script ffmpeg-download.ps1 in the directory <OPENVINO_DIR>\opencv\
Right click on this script, and then "Run with PowerShell".
BKKUEH
I was trying to run "interactive_face_detection_demo.exe" in Win10 using ToolKit2020r4 with an IP camera via rtsp url.
Encounter error "OpenCV(4.4.0-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\2020.4\build\windows\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file)"
Resolved by executing "ffmpeg-download.ps1" in the directory <OPENVINO_DIR>\opencv\ on PowerShell
(Do need to ensure that the script is run with administrator rights and enable remotesigned policy prior to executing "ffmpeg-download.ps1")
la__xl
Same issue here, I have followed  Max L. (Intel)'s advice to installed FFmpeg, when I try to create an avi file of fourcc MJPG, it will complain unsupported Fourcc
2544-Thread-4 2020-06-19 23:09:27,232 videoRecord.py:84 prepareWriter DEBUG - create a new file: mov/idle-2020-06-19-23-09-25.avi
2544-Thread-4 2020-06-19 23:09:37,278 videoRecord.py:76 prepareWriter DEBUG - close avi file
then I changed to XVID / mp4, still complaints here
MFX: Unsupported FourCC: XVID (0x44495658)
6336-Thread-4 2020-06-19 23:12:07,695 videoRecord.py:84 prepareWriter DEBUG - create a new file: mov/idle-2020-06-19-23-12-05.mp4
6336-Thread-4 2020-06-19 23:12:17,754 videoRecord.py:76 prepareWriter DEBUG - close avi file
Max_L_Intel
Hi la, xl
The following formats are only supported: AVC (X264, H264, AVC), HEVC (H265, HEVC), MPEG2. If you use different format, you'll see this error message.
la__xl
hi Max_l,
  I have create cv2.VideoWriter using VideoWriter_fourcc to indicate Encoder format,
 I could not found AVC/HEVC/MPEG2 in here FOURCC
ffmpeg output,
  libavutil      56. 54.100 / 56. 54.100
  libavcodec     58. 92.100 / 58. 92.100
  libavformat    58. 46.101 / 58. 46.101
  libavdevice    58. 11.100 / 58. 11.100
  libavfilter     7. 86.100 /  7. 86.100
  libswscale      5.  8.100 /  5.  8.100
  libswresample   3.  8.100 /  3.  8.100
  libpostproc    55.  8.100 / 55.  8.100
 DEV.LS h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_qsv h264_cuvid ) (encoders: libx264 libx264rgb h264_amf h264_mf h264_nvenc h264_qsv nvenc nvenc_h264 )
 DEV.L. hevc                 H.265 / HEVC (High Efficiency Video Coding) (decoders: hevc hevc_qsv hevc_cuvid ) (encoders: libx265 nvenc_hevc hevc_amf hevc_mf hevc_nvenc hevc_qsv )
 DEVIL. mjpeg                Motion JPEG (decoders: mjpeg mjpeg_cuvid mjpeg_qsv ) (encoders: mjpeg mjpeg_qsv )
 DEV.L. mpeg2video           MPEG-2 video (decoders: mpeg2video mpegvideo mpeg2_qsv mpeg2_cuvid ) (encoders: mpeg2video mpeg2_qsv )
 D.V.L. vc1                  SMPTE VC-1 (decoders: vc1 vc1_qsv vc1_cuvid )
 DEV.L. vp8                  On2 VP8 (decoders: vp8 libvpx vp8_cuvid vp8_qsv ) (encoders: libvpx )
 DEV.L. vp9                  Google VP9 (decoders: vp9 libvpx-vp9 vp9_cuvid vp9_qsv ) (encoders: libvpx-vp9 vp9_qsv )
astrid24
I am facing the same error. Output video file is not generated. I'm using OpenVINO 2020.4
I executed the downloader script ffmpeg-download.ps1 on PowerShell. But, still facing the same error.
Can you let me know if you were able to resolve this issue. Thank you.
