6595 Discussions
Issue compiling inference-tutorials-generic samples
PeterFerranti
It says it cant find gflags but I know its installed to the latest version.
-- InferenceEngine_DIR=/opt/intel/openvino_2020.3.194/deployment_tools/inference_engine/share
-- CMAKE_MODULE_PATH=/opt/intel/openvino_2020.3.194/deployment_tools/inference_engine/share/../samples/cmake
-- Looking for inference engine configuration file at: /home/localadmin/Desktop/WORKSPACES/OpenVINO/inference-tutorials-generic-openvino_toolkit_2019_r1_0/face_detection_tutorial/share
-- CMAKE_BUILD_TYPE not defined, 'Release' will be used
CMake Error at /home/localadmin/Desktop/WORKSPACES/OpenVINO/inference-tutorials-generic-openvino_toolkit_2019_r1_0/face_detection_tutorial/cmake/CMakeLists_common.cmake:135 (message):
  The required 'gflags' library was not found in the Inference Engine's
  samples at:
  /opt/intel/openvino_2020.3.194/deployment_tools/inference_engine/share/../samples/thirdparty/gflags
Call Stack (most recent call first):
  CMakeLists.txt:17 (include)
-- Configuring incomplete, errors occurred!
See also "/home/localadmin/Desktop/WORKSPACES/OpenVINO/inference-tutorials-generic-openvino_toolkit_2019_r1_0/face_detection_tutorial/step_2/build/CMakeFiles/CMakeOutput.log".
Iffa_Intel
Greetings,
Did you try to uninstall and re-install your cmake? (CMake 3.4 OR Higher)
You can refer here for CMake installation: https://cmake.org/download/
If you are using Windows, it's better to go with .msi
Do let me know if the problem still persist after the re-installation
Sincerely,
Iffa
WangSiqi
Hi, I ran into the exact same problem when I make the step_1 demo. I tried reinstall cmake but problem remains.
It turned out that the newest version of openvino stores the gflag file in the "/opt/intel/openvino_2020.3.194/deployment_tools/inference_engine/share/../samples/cpp/thirdparty/gflags" directory.
You need to configure the cmake file in the cmake directory:
~/tutorials/inference-tutorials-generic/face_detection_tutorial/cmake$   gedit CMakeLists_common.cmake
replace line 29 with the following code:
set(InferenceEngine_Samples_DIR "$ENV{InferenceEngine_DIR}/../samples/cpp" )
Hopes it solves your problem~
