6581 Discussions
OpenCV(4.5.1-openvino): error: (-5:Bad argument) CAP_IMAGES: can't find starting number
jobdulo
I have converted an ONNX model file to the OpenVINO IR format.
I am running a demo using the following command to test the IR format :
python yolo__openvino_demo.py -m "C:\Program Files (x86)\IntelSWTools\openvino_2021.2.185\deployment_tools\model_optimizer\yolov4-p5.xml" -i .\images\bus.jpg -at yolov4-p5
from which I get the following error
 OpenCV(4.5.1-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\2021.2\build\windows\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file): .\images\bus.jpg in function 'cv::icvExtractPattern'
What I have tried:
Stepping down the OpenVINO version to 2020.3.341 but it could not even convert ONNX file to IR as per the instructions at:
https://github.com/Chen-MingChang/pytorch_YOLO_OpenVINO_demo
I have also looked at the following solved question on the forum:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/OpenCV-4-1-2-openvino-CAP-IMAGES-can-t-find-starting-number-in/m-p/1129111
but this is a video file problem. Mine is an image file problem.
Labels (2)
Zulkifli_Intel
Hello Job Dulo,
Greetings to you.
Have you try these recommendations:
  • Install FFmpeg as VideoCapture backend (on Windows you need to download the OpenCV community plugin. There's a downloader script in the package: openvino\opencv\ffmpeg-download.ps1. Right-click on it - Run with PowerShell).
If you don't, please give it a try and share with us the result.
Zulkifli
jobdulo
Hey Zulkifli,
Thank you for the response. I have done the following:
  1. Downloaded the OpenCV from https://docs.opencv.org/3.4/d3/d52/tutorial_windows_install.html using the instructions under Installation by Using the Pre-built Libraries
  2. I have right-click on ffmpeg-download.ps1 and run with PowerShell
  3. Tried the inferencing one more time
But the error still persists.
Have I missed anything?
Maksim_S_Intel
This application reads an input using OpenCV's `VideoCapture` class, it only supports images with numbers in names, e.g. "frame0001.jpg". So you can just rename your input file to "bus0.jpg".
jobdulo
Hey Maksim, renaming the file seems to remove the error but the application hangs from here on.
Zulkifli_Intel
Hello Job Dulo,
Have you rebooted your system after installing FFmpeg? Reboot is required after installing FFmpeg.
Zulkifli
jobdulo
I skipped this part. I did not install FFmpeg.  Is this the right place to download it from https://www.ffmpeg.org/download.html#build-windows ?
Zulkifli_Intel
Hello Job Dulo.
You can find the FFmpeg here "C:\<Installation Path>\openvino_2021.3.394\opencv\ffmpeg-download.ps1". Right-click on it - Run with PowerShell). Once installation is completed, reboot your PC.
Zulkifli
jobdulo
Hey Zulkifli,
I had done exactly that but nothing happened on the powershell. It popped up, blinked, and exited. No output was given.
Zulkifli_Intel
Hello Job Dulo,
Go to this directory:
“C:\<install_directory>\openvino_2021.2.185\opencv\bin”
Delete the file opencv_videoio_ffmpeg451_64.dll
Rerun the ffmpeg-download.ps1 using Powershell. You will see this:
Zulkifli
Zulkifli_Intel
Hello Job Dulo,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
