6574 ディスカッション
OpenCV Error creating VIdeoWriter object
DaveInPA
新規コントリビューター I
6,412件の閲覧回数
I'm on windows 10 (64 bit) and finally got OpenVino installed and working correctly using the windows installation tool. I had to run the "setupvars.bat" batch program and then see the resulting environment variables to set manually at the system level for it to work. I also installed Python 3.8.10. Before i started i removed anything remotely connected to prior OpenCV installations.
when i try to create a VideoWriter object using....
fourcc = cv2.VideoWriter_fourcc( 'M', 'J', 'P', 'G')
out = cv2.VideoWriter('Videos\driveway.avi', fourcc, 20.0, (640, 480))
i'm getting the following errors:
MFX: Can't initialize session
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.4\build\windows\opencv\modules\videoio\src\cap.cpp (589) cv::VideoWriter::open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.5.3-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\2021.4\build\windows\opencv\modules\videoio\src\cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can't find
starting number (in the name of file): Videos\driveway.avi in function 'cv::icvExtractPattern'
Somewheres on the Internet they said i'm missing "opencv_videoio_ffmpeg_64.dll" which i was. So i found a copy of that somewhere and put that into my opencv/bin directory. I've tried different codecs and other Python programs but getting the same results.
Any idea what causes this?
0 件の賞賛
1 解決策
DaveInPA
新規コントリビューター I
6,376件の閲覧回数
** SOLVED **
For whatever reason the OpenVino windows installed failed to install a few dlls/libs. From the opencv folder there is a POWERSHELL script called ffmpeg-download.ps1 that needs to be run that will install the missing files. Not sure why there is a script to do this and maybe that script wasn't executed during the install?
Regardless run that script and you'll get past this problem...
元の投稿で解決策を見る
6 返答(返信)
DaveInPA
新規コントリビューター I
6,377件の閲覧回数
** SOLVED **
Zulkifli_Intel
モデレーター
6,369件の閲覧回数
Hello David Rosner,
Have you installed FFmpeg on your Windows 10? Here is the quickstep to install it:
  1. Go to this directory: C:\Program Files (x86)\Intel\openvino_2021.4.582\opencv
  2. Right-click on ffmpeg-download.ps1
  3. Click on Run with PowerShell
  4. Reboot your PC once the installation is done.
Please let us know whether the above method resolves the issue or not.
Sincerely,
Zulkifli
DaveInPA
新規コントリビューター I
6,361件の閲覧回数
Hi - Yes i eventually figured out i needed to do that and discovered that script. Solve that problem! You should ask the team who owns the windows installer product to add that to the step.
Zulkifli_Intel
モデレーター
6,336件の閲覧回数
Hello David Rosner,
Thank you for your feedback. We will inform the developer of this matter.
Sincerely,
Zulkifli
Zulkifli_Intel
モデレーター
6,274件の閲覧回数
Hello DaveInPA,
The step to install the FFmpeg can be found in the demos documentation such as:
-       3D Human Pose Estimation Python* Demo
-       Action Recognition Python* Demo
-       Crossroad Camera C++ Demo
Sincerely,
Zulkifli
Zulkifli_Intel
モデレーター
6,198件の閲覧回数
Hello DavelnPA,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
返信
