6574 Discussions
OpenCV uninstall starting Installation failed. Error on line 118 make: *** [uninstallopencv] Error 1
Followed the installation command git clone -b ncsdk2 http://github.com/Movidius/ncsdk && cd ncsdk && make install, the command were ran using MINGW64 on windows 10.
The error popped up
./uninstall-opencv.sh
Not sure how to get by the issue, MINGW64 were executed by administrator right. Kindly advise..
Hi @marzious
Currently the NCSDK is only supported on Ubuntu 16.04 or Raspbian for the RPi. Have you tried setting up a virtual machine running Ubuntu on your Windows 10 system?
Take a look at the following link for Installation and Configuration instructions for a virtual machine.
https://movidius.github.io/ncsdk/vm_config.html
Jesus
I have also met this error on Ubuntu Linux 16.04. Is there any help?
