6605 Discussions
OpenVINO GPU Inference with a Multiple Graphic Card System
Rosten__Erik
Hi everyone, I'm relatively new to the OpenVINO/NCS2 community. I'm trying to benchmark a model on the CPU/GPU/NCS2 and am getting a bit confused as to how the GPU device setting is working. My setup is an Nvidia 1080 Ti and Nvidia 960, with an Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, that has an Intel® UHD Graphics 630. When I run the GPU setting comparing an OpenVINO optimized model vs an optimized tensorflow protobuf file, I'm getting image/sec framerates of 200 vs 25k, leading me to wonder whether I've set everything up right. Running clinfo gives
Number of platforms                               2
  Platform Name                                   Intel(R) OpenCL HD Graphics
  Platform Vendor                                 Intel(R) Corporation
  Platform Version                                OpenCL 2.1
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_depth_images cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_subgroups cl_intel_required_subgroup_size cl_intel_subgroups_short cl_khr_spir cl_intel_accelerator cl_intel_media_block_io cl_intel_driver_diagnostics cl_intel_device_side_avc_motion_estimation cl_khr_priority_hints cl_khr_throttle_hints cl_khr_create_command_queue cl_khr_fp64 cl_khr_subgroups cl_khr_il_program cl_intel_spirv_device_side_avc_motion_estimation cl_intel_spirv_media_block_io cl_intel_spirv_subgroups cl_khr_spirv_no_integer_wrap_decoration cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_intel_planar_yuv cl_intel_packed_yuv cl_intel_motion_estimation cl_intel_advanced_motion_estimation cl_intel_va_api_media_sharing
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             INTEL
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.2 CUDA 9.0.368
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Platform Extensions function suffix             NV
Number of devices                                 1
  Device Name                                     Intel(R) Gen9 HD Graphics NEO
  Device Vendor                                   Intel(R) Corporation
  Device Vendor ID                                0x8086
  Device Version                                  OpenCL 2.1 NEO
  Driver Version                                  19.16.12873
  Device OpenCL C Version                         OpenCL C 2.0
  Device Type                                     GPU
  Device Profile                                  FULL_PROFILE
  Max compute units                               24
  Max clock frequency                             1200MHz
  Device Partition                                (core)
    Max number of sub-devices                     0
    Supported partition types                     None
  Max work item dimensions                        3
  Max work item sizes                             256x256x256
  Max work group size                             256
  Preferred work group size multiple              32
  Max sub-groups per work group                   32
  Preferred / native vector sizes
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 1 / 1
    half                                                 8 / 8        (cl_khr_fp16)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  No
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Round to zero                                 Yes
    Correctly-rounded divide and sqrt operations  Yes
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
  Address bits                                    64, Little-Endian
  Global memory size                              13215203328 (12.31GiB)
  Error Correction support                        No
  Max memory allocation                           4294959104 (4GiB)
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   No
    Fine-grained system sharing                   No
    Atomics                                       No
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       1024 bits (128 bytes)
  Preferred alignment for atomics
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         64 bytes
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             4294959104 (4GiB)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        524288
  Global Memory cache line                        64 bytes
  Image support                                   Yes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            268434944 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   4 bytes
    Pitch alignment for 2D image buffers          4 bytes
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             16384x16384x2048 pixels
    Max number of read image args                 128
    Max number of write image args                128
    Max number of read/write image args           128
  Max number of pipe args                         16
  Max active pipe reservations                    1
  Max pipe packet size                            1024
  Local memory type                               Local
  Local memory size                               65536 (64KiB)
  Max constant buffer size                        4294959104 (4GiB)
  Max number of constant args                     8
  Max size of kernel argument                     1024
  Queue properties (on host)
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                131072 (128KiB)
    Max size                                      67108864 (64MiB)
  Max queues on device                            1
  Max events on device                            1024
  Prefer user sync for interop                    Yes
  Profiling timer resolution                      83ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            No
    Sub-group independent forward progress        Yes
    IL version                                    SPIR-V_1.0
    SPIR versions                                 1.2
  printf() buffer size                            4194304 (4MiB)
  Built-in kernels                                block_motion_estimate_intel;block_advanced_motion_estimate_check_intel;block_advanced_motion_estimate_bidirectional_check_intel;
  Motion Estimation accelerator version	(Intel)   2
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Device Extensions                               cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_depth_images cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_subgroups cl_intel_required_subgroup_size cl_intel_subgroups_short cl_khr_spir cl_intel_accelerator cl_intel_media_block_io cl_intel_driver_diagnostics cl_intel_device_side_avc_motion_estimation cl_khr_priority_hints cl_khr_throttle_hints cl_khr_create_command_queue cl_khr_fp64 cl_khr_subgroups cl_khr_il_program cl_intel_spirv_device_side_avc_motion_estimation cl_intel_spirv_media_block_io cl_intel_spirv_subgroups cl_khr_spirv_no_integer_wrap_decoration cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_intel_planar_yuv cl_intel_packed_yuv cl_intel_motion_estimation cl_intel_advanced_motion_estimation cl_intel_va_api_media_sharing
Number of devices                                 2
  Device Name                                     GeForce GTX 1080 Ti
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.2 CUDA
  Driver Version                                  384.130
  Device OpenCL C Version                         OpenCL C 1.2
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 02:00.0
  Max compute units                               28
  Max clock frequency                             1582MHz
  Compute Capability (NV)                         6.1
    Max number of sub-devices                     1
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
  Half-precision Floating-point support           (n/a)
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Global memory size                              11715084288 (10.91GiB)
  Max memory allocation                           2928771072 (2.728GiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
  Alignment of base address                       4096 bits (512 bytes)
  Global Memory cache size                        458752
  Global Memory cache line                        128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            134217728 pixels
    Max 2D image size                             16384x32768 pixels
    Max 3D image size                             16384x16384x16384 pixels
    Max number of read image args                 256
    Max number of write image args                16
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max constant buffer size                        65536 (64KiB)
  Max number of constant args                     9
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Profiling                                     Yes
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
    Kernel execution timeout (NV)                 No
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  2
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Device Name                                     GeForce GTX 960
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 01:00.0
  Max compute units                               8
  Max clock frequency                             1177MHz
  Compute Capability (NV)                         5.2
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Global memory size                              4232183808 (3.942GiB)
  Max memory allocation                           1058045952 (1009MiB)
  Global Memory cache size                        131072
  Image support                                   Yes
    Max 3D image size                             4096x4096x4096 pixels
  Queue properties
    Profiling                                     Yes
    Kernel execution timeout (NV)                 Yes
  Built-in kernels
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  No platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   No platform
  clCreateContext(NULL, ...) [default]            No platform
  clCreateContext(NULL, ...) [other]              Success [INTEL]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
	NOTE:	your OpenCL library only supports OpenCL 2.0,
		but some installed platforms support OpenCL 2.1.
		Programs using 2.1 features may crash
		or behave unexepectedly
and running lspci | grep VGA gives
01:00.0 VGA compatible controller: NVIDIA Corporation GM206 [GeForce GTX 960] (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation Device 1b06 (rev a1)
I've read on other forum posts that a multiple GPU system might need some additional configuration to make sure the Intel Graphics are being detected by OpenCL. Does everything seem right here, or is there further room for optimization? Is there any detailed documentation on making a GPU device work properly in a multiple graphic card system? Thanks in advance.
Best,
Erik
Michael_C_Intel1
Hello ErikR,
Thanks for the question.
From an OpenCL on Intel Graphics perspective...
Assuming that's common clinfo source then Intel Graphics is being detected OK via OpenCL api...
Unfortunately we can't provide support for non-Intel products, but... if a sighting is observed where an Intel software/hardware stack conflicts per some specification or device targeting is confusing or untenable we want to know about it. Appreciate you sharing your experience.
Can you share how you installed the OpenCL runtime for Intel Graphics? From where you obtained the runtime?
On OpenVINO...
Some of the default information for forum post feedback you've already provided, but can you share the rest of the following?
Please let us know what Processor, Operating System, Graphics Driver Version, and Tool Version you are using
Please state steps to reproduce the issue as precisely as possible
If you are using command line tools, please provide the full command line
If code is involved, create a small "Reproducer" sample and attach it to the message
Here, tool version is the version of OpenVINO.
Can you share how you are looking to target Intel Graphics with OpenVINO through a source code example?
Can you share the protobufs and openvino models? Where are you targeting each run and through what engine stacks?... Can you clarify what you're trying to compare for performance, where it's running and with what stacks?
Also, please don't share any privileged source or data. Thanks!
-MichaelC
Rosten__Erik
Hi MichaelC,
Thanks for the response.
I've installed openCL through the directions on the best reponse of this form post here.
I then installed clinfo through
sudo apt install clinfo
I'm using Ubuntu 16.04.5 LTS. Since I've installed based on the forum post, looks like the graphics driver version is 18.43. My OpenVINO version is 2019.1.133.
A short snippet of how I'm attempting to target the Intel GPU is:
load_time = time.time()
	plugin = IEPlugin(device='GPU')
	net = IENetwork(model=model_xml, weights=model_bin)
	input_blob = next(iter(net.inputs))
	out_blob = next(iter(net.outputs))
	net.batch_size = inputs_count
	exec_net = plugin.load(network=net)
	del net
	out_node_name = 'layer_out_1/MatMul'
	print(time.time() - load_time)
	total_time = 0;
	for i in range(100):
		t1 = time.time()
		res = exec_net.infer(inputs={input_blob: images})
		y_pred = res[out_node_name]
		t2 = time.time()
		delta_time = t2 - t1
		total_time += delta_time
	avg_time = total_time / n_time_inference
	print(avg_time)
	print(len(images)/avg_time)
I unfortunately cannot share the protobufs and openvino models, and am unsure about how to report back on what engine stacks are being used. Sorry about that. When testing the protobuf file to compare performance, I'm using
		t1 = time.time()
		predictions = sess.run(out_tensor, {'import/layer_in_1:0': x_test_1})
		t2 = time.time()
to compare the times. Thanks again for your help.
Best,
Erik
