6585 Discussions
OpenVINO InferenceEngine::GeneralError in Loading Model Network
Lukech
Hello.
I recently changed openvino version to 23.0 in my own project.
During changing version, i replaced some InferenceEngine code and sdk files (dll, lib).
but there are some error occurs when i excute my program.
There is no problem on the surface in obtaining the inference process and the result value,
but I want to deal with the cause of the error that occurs, but there is no way to grasp it.
The error contents are as below follows.
* Microsoft C++ Exception : InferenceEngine::GeneralError, Memory Location
I really hope to handle this problem correctly.
kind regards
Luke
Lukech
additionaly specific code is below.
error occurs same
InferenceEngine API
net = ie.ReadNetwork(modelPath);
compiled_net = ie.LoadNetwork(net , "CPU");
OpenVINO API v2.0
net = core.read_model(modelPath);
compiled_net = core.compile_model(model, "CPU");
Megat_Intel
Hi Luke,
Did you encounter this error in Microsoft Visual Studio output as shown here?
For your information, the exceptions you observed are normal behavior. The errors are internal exceptions that have already been handled internally by OpenVINO™, and they don't affect the code execution.
It is just how OpenVINO™ works internally. That also explains why the error messages are not displayed in the command prompt. You can refer to the Exception Thrown When Running Hello Classification Sample in Visual Studio* Output page for more information, Thank you.
Megat
Lukech
Thanks for replying.
I understood that it doesn't matter while executing  codes.
But, i wonder that why does these errors happen in codes.
The reason why I'm asking is to judge the probability about terminating code of a problem that may arise later.
if you hard to answer that, can you describe simple reason about that error?
kind regards
Luke
Megat_Intel
Hi Luke,
We apologize for the delay.
For your information, in general, those internal exceptions are used when one plugin cannot support some property or function in one release. So same application may hit different internal exceptions in different releases. It is not an issue if an unsupported property or function does not block your use cases.
If this error is still blocking your use cases, please provide more details and information regarding your use case and how it's blocking it.
Megat
Megat_Intel
Hi Luke,
Thank you for your question. This thread will no longer be monitored since we have provided an explanation. If you need any additional information from Intel, please submit a new question.
Megat
