openVINO not detected Flex140
WeiSeng
Hi Team,
I like to check if you have solution below:
When I launch OpenVINO notebook, I only detected the CPU and not detected Flex140 GPU. I follow this guide to configure the Flex140: https://dgpu-docs.intel.com/driver/installation.html
And already installed all the driver and configure. Even on sycl-ls i can detected the Flex140 GPU as attached.
Anyone know what configuration steps missing?
WeiSeng
From the previous conversation, already mentioned that follow this link installed the driver and modules/lib. https://dgpu-docs.intel.com/driver/installation.html
And all the lib that you mentioned already installed like below command. Btw, I managed to solve this issue. and I provided BKC to  hari.chand.balasubramaniam@intel.com, you can contacted him.
Compute and Media Runtimes
sudo dnf install -y \
  intel-opencl intel-media intel-mediasdk libmfxgen1 libvpl2\
  level-zero intel-level-zero-gpu mesa-dri-drivers mesa-vulkan-drivers \
  mesa-vdpau-drivers libdrm mesa-libEGL mesa-libgbm mesa-libGL \
  mesa-libxatracker libvpl-tools intel-metrics-discovery \
  intel-metrics-library intel-igc-core intel-igc-cm \
  libva libva-utils intel-gmmlib libmetee intel-gsc intel-ocloc
Aznie_Intel
Hi WeiSeng,
Thanks for reaching out.
Which OpenVINO notebook sample you are running and can you share the error when you run the inference with GPU plugin? Have you tried to restart the kernel?
You may share your operation system and OpenVINO version for us to further troubleshoot this.
Aznie
WeiSeng
Hi
The openVINO notebook I am using this https://github.com/openvinotoolkit/openvino_notebooks
And inside the notebook, that have sample code to validate the GPU, the notebook name " 108-gpu-device" after clone from this source.
when running code below, cannot detected GPU, only detected CPU only.
import openvino as ov
core = ov.Core()
core.available_devices
Aznie_Intel
Hi WeiSeng,
We're investigating this issue and will get back to you as soon as possible.
Aznie
Aznie_Intel
Hi WeiSeng,
Have you installed the OpenCL packages before? If not please install OpenCL packages with the command below:
apt-get install -y ocl-icd-libopencl1 intel-opencl-icd intel-level-zero-gpu level-zero
You may also refer to the instructions on this page.
Hope this helps.
Aznie
WeiSeng
Aznie_Intel
Hi Wei Seng,
I am glad that your issue is resolved and thanks for sharing your resolution in this community. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
