OpenVINO: MYRIAD RuntimeError
Han__Tianyi
I am running into some trouble when trying to use Inference Engine on the NCS through the python API (python 3.7.3, Host Windows 10, ONNX PyTorch)
I don't see this error with this same model for CPU or GPU. The error is in the code of creating exe_net
exec_net = plugin.load(network=net)
Traceback (most recent call last):
  File "C:/Users/Hans/Desktop/alexnet_vote/test.py", line 204, in <module>
    main(testdata, test_mapping)
  File "C:/Users/Hans/Desktop/alexnet_vote/test.py", line 138, in main
  File "ie_api.pyx", line 551, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 561, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Failed to infer shapes for Reshape layer (38) with error: Invalid reshape mask (dim attribute): number of elements in input: [1,256,6,6] and output: [10,9216] mismatch
		<layer id="16" name="38" precision="FP16" type="Reshape">
			<input>
				<port id="0">
					<dim>10</dim>
					<dim>256</dim>
					<dim>6</dim>
					<dim>6</dim>
				</port>
				<port id="1">
					<dim>2</dim>
				</port>
			</input>
			<output>
				<port id="2">
					<dim>10</dim>
					<dim>9216</dim>
				</port>
			</output>
		</layer>
Shubha_R_Intel
Dear Han, Tianyi,
Are you using the latest OpenVino Release 20192.01 ?
Looking at the error 256*6*6 = 9216. But the first position 1 is batch size. What happens when you re-run model optimizer this time with  --batch 10 ?
thanks,
Shubha
