6583 Discussions
OpenVINO Python version (2024.1.0-15008-f4afc983258-releases/2024/1) mismatches with OpenVINO Runtim
Samarth2
Hi team
While executing openvino yolo v3 model i ended with this error
kindly help us in solving this error
ImportError Traceback (most recent call last)
File ~/YOLOv3/object_detection_demo_yolov3_async.py:27
24 from time import time
26 import cv2
---> 27 from openvino.inference_engine import IENetwork, IECore
29 basicConfig(format="[ %(levelname)s ] %(message)s", level=logging.INFO, stream=sys.stdout)
30 log = logging.getLogger()
File /opt/intel/oneapi/intelpython/openvino_2024.1.0/python/openvino/__init__.py:21
13 pass
15 # #
16 # # OpenVINO API
17 # # This __init__.py forces checking of runtime modules to propagate errors.
18 # # It is not compared with init files from openvino-dev package.
19 # #
20 # Import all public modules
---> 21 from openvino import runtime as runtime
22 from openvino import frontend as frontend
23 from openvino import helpers as helpers
File /opt/intel/oneapi/intelpython/openvino_2024.1.0/python/openvino/runtime/__init__.py:8
5 """openvino module namespace, exposing factory functions for all ops and other classes."""
6 # noqa: F401
----> 8 from openvino._pyopenvino import get_version
10 __version__ = get_version()
12 # Openvino pybind bindings and python extended classes
ImportError: Check 'versions_compatible' failed at ../../repos/openvino/src/bindings/python/src/pyopenvino/pyopenvino.cpp:93:
OpenVINO Python version (2024.1.0-15008-f4afc983258-releases/2024/1) mismatches with OpenVINO Runtime library version (2024.1.0-33-20d7ce923d1). It can happen if you have 2 or more different versions of OpenVINO installed in system. Please ensure that environment variables (e.g. PATH, PYTHONPATH) are set correctly so that OpenVINO Runtime and Python libraries point to same release.
Megat_Intel
Hi Samarth2,
We noticed you have posted a similar question in this thread. Therefore, this thread will no longer be monitored, and we will continue to support you in this thread.
Megat
