Hi team
While executing openvino yolo v3 model i ended with this error
kindly help us in solving this error
ImportError Traceback (most recent call last)
File ~/YOLOv3/object_detection_demo_yolov3_async.py:27
24 from time import time
26 import cv2
---> 27 from openvino.inference_engine import IENetwork, IECore
29 basicConfig(format="[ %(levelname)s ] %(message)s", level=logging.INFO, stream=sys.stdout)
30 log = logging.getLogger()
File /opt/intel/oneapi/intelpython/openvino_2024.1.0/python/openvino/__init__.py:21
13 pass
15 # #
16 # # OpenVINO API
17 # # This __init__.py forces checking of runtime modules to propagate errors.
18 # # It is not compared with init files from openvino-dev package.
19 # #
20 # Import all public modules
---> 21 from openvino import runtime as runtime
22 from openvino import frontend as frontend
23 from openvino import helpers as helpers
File /opt/intel/oneapi/intelpython/openvino_2024.1.0/python/openvino/runtime/__init__.py:8
5 """openvino module namespace, exposing factory functions for all ops and other classes."""
6 # noqa: F401
----> 8 from openvino._pyopenvino import get_version
10 __version__ = get_version()
12 # Openvino pybind bindings and python extended classes
ImportError: Check 'versions_compatible' failed at ../../repos/openvino/src/bindings/python/src/pyopenvino/pyopenvino.cpp:93:
OpenVINO Python version (2024.1.0-15008-f4afc983258-releases/2024/1) mismatches with OpenVINO Runtime library version (2024.1.0-33-20d7ce923d1). It can happen if you have 2 or more different versions of OpenVINO installed in system. Please ensure that environment variables (e.g. PATH, PYTHONPATH) are set correctly so that OpenVINO Runtime and Python libraries point to same release.
