6574 讨论
OpenVINO R3 RuntimeError: Failed to create plugin libdliaPlugin.so for device FPGA
azmat
初学者
845 次查看
I'm encountering the following issue in R3 of OpenVINO when running a reference image classifier application in Ubuntu18.  I've stepped through the instructions at https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R3.html without any errors.  The problem however appears to be in the OpenCL driver side.
2019-12-04 18:26:58.959115: W tensorflow/compiler/jit/mark_for_compilation_pass.cc:1412] (One-time warning): Not using XLA:CPU for cluster because envvar TF_XLA_FLAGS=--tf_xla_cpu_global_jit was not set.  If you want XLA:CPU, either set that envvar, or use experimental_jit_scope to enable XLA:CPU.  To confirm that XLA is active, pass --vmodule=xla_compilation_cache=1 (as a proper command-line flag, not via TF_XLA_FLAGS) or set the envvar XLA_FLAGS=--xla_hlo_profile.
Warning: Cannot find any Intel(R) FPGA Board libraries. No Intel(R) FPGA devices will be loaded. Please contact your board vendor or see section "Linking Your Host Application to the Khronos ICD Loader Library" of the Programming Guide to set up FCD manually.
ERROR: UNRECOGNIZED ERROR CODE (-1001)
Location: /teamcity/work/scoring_engine_build/releases_2019_R3/thirdparty/dla/runtime/core/src/AOCL_Utils.cpp:279
Query for number of platforms failed
Traceback (most recent call last):
  File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
    exec(code, run_globals)
    return self.ie.load_network(network=self.net, device_name=device)
  File "ie_api.pyx", line 85, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 92, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Failed to create plugin /opt/intel/openvino_2019.3.334/deployment_tools/inference_engine/lib/intel64/libdliaPlugin.so for device FPGA
Please, check your environment
Error: Failure due to generic standard exception.
Additionally, the strange thing is the AOCL_Utils.cpp path being referenced above doesn't exist on my local machine.  Is it possible I linked in a bad library?
Hardware: IEI Mustang card
Software: Ubuntu 18, OpenVINO R3, Quartus 18.1
0 项奖励
0 回复数
回复
