Hi, when I compile my code for HETERO:FPGA,CPU I get the next message
Can't get executable graph: Failed to create plugin /opt/intel/2019_r1/openvino_2019.2.275/deployment_tools/inference_engine/lib/intel64/libdliaPlugin.so for device FPGA
Please, check your environment
Cannot load library '/opt/intel/2019_r1/openvino_2019.2.275/deployment_tools/inference_engine/lib/intel64/libdliaPlugin.so': libalteracl.so: cannot open shared object file: No such file or directory
I use the OpenVINO stater kit iso with R1 distribution but I installed R2 distribution and my code works well using CPU parameter, but HETERO parameter does not work
Facing similar issue in Aug 2020 Version also
