I am trying to build OpenVINO from source in Ubuntu 20.04 in Raspberry Pi 4 4-GB.
I was previously suggested by this steps at the intel forum - OpenVINO toolkit for Ubuntu 22.04 on Raspberry Pi 4
I followed the build steps from https://github.com/openvinotoolkit/openvino/wiki/BuildingForLinux
I used the command inside the build folder to create CMake dependencies which works correctly :
cmake -DCMAKE_BUILD_TYPE=Release -DENABLE_PYTHON=ON -DENABLE_WHEEL=ON ..
When I try to build the project using the following command, I get the error at [98%] :
make --jobs=$(nproc --all)
The build process took almost 4-5 hours. I was stuck at 98% for an hour and then I got this error for build fail.
Error message
[ 98%] Built target py_onnx_frontend
[ 98%] Built target py_ov_frontends
[ 98%] Built target template_extension
c++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/build.make:174: src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/evaluates_map.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:4975: src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/all] Error 2
make: *** [Makefile:166: all] Error 2
I have attached a screenshot of the error I get while building OpenVINO
Thank you
your question was answered in this GitHub discussion.
Please help to refer to that thread.
Cordially,
Iffa
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
