6584 Discussions
OpenVINO build from source failed in Ubuntu 20.04 in Raspberry Pi
nilutpol_kashyap
I am trying to build OpenVINO from source in Ubuntu 20.04 in Raspberry Pi 4 4-GB.
I was previously suggested by this steps at the intel forum - OpenVINO toolkit for Ubuntu 22.04 on Raspberry Pi 4
I followed the build steps from https://github.com/openvinotoolkit/openvino/wiki/BuildingForLinux
I used the command inside the build folder to create CMake dependencies which works correctly :
cmake -DCMAKE_BUILD_TYPE=Release -DENABLE_PYTHON=ON -DENABLE_WHEEL=ON ..
When I try to build the project using the following command, I get the error at [98%] :
make --jobs=$(nproc --all)
The build process took almost 4-5 hours. I was stuck at 98% for an hour and then I got this error for build fail.
Error message
[ 98%] Built target py_onnx_frontend
[ 98%] Built target py_ov_frontends
[ 98%] Built target template_extension
c++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/build.make:174: src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/evaluates_map.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:4975: src/plugins/template/backend/CMakeFiles/interpreter_backend.dir/all] Error 2
make: *** [Makefile:166: all] Error 2
I have attached a screenshot of the error I get while building OpenVINO217065094-0d071f98-37d2-4ca7-b2b9-5fe755448496.png
Thank you
Iffa_Intel
your question was answered in this GitHub discussion.
Please help to refer to that thread.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
