6575 Discussions
OpenVINO inference engine legacy lib linking on Windows 10
Domi
I'm using OpenVINO version 2021.4.2 and trying to build a plugin that has dependency on inference_engine_legacy dll (Windows build).
First thing I noticed is that the corresponding inference_engine_legacy .lib file is missing from the install package.
I downloaded 2021.4.2 version from github and compiled on Windows using VS2019.
Having now the inference_engine_legacy.lib tried to build a dll but I got a LNK2019 error regarding
ngraph::pass::ConvertOpSet1ToLegacy::type_info
Narrowed down the issue to this small code:
#include <memory>
#include "ngraph/function.hpp"
#include "ngraph/pass/manager.hpp"
#include "ngraph_transformations.hpp"
#include "transformations/convert_reduce_to_pooling.hpp"
#include "transformations/convert_opset1_to_legacy.hpp"
#include "transformations/common_optimizations.hpp"
#include "transformations/convert_interpolate_to_interp_or_resample.hpp"
#include "transformations/transpose_to_reshape.hpp"
#include "transformations/convert_minimum_to_power_and_max.hpp"
void my_ngraph_transformations(std::shared_ptr<ngraph::Function> ngraph_function) {
ngraph::pass::Manager manager;
// Optimizes ngraph function. Does optimizations such as removing useless consts or nodes with useless shape info
manager.register_pass<ngraph::pass::CommonOptimizations>();
// Converts some reducemean to pooling layers
manager.register_pass<ngraph::pass::ConvertReduceToPooling>();
// Converts the entire opset 1 into legacy or inference engine representation
manager.register_pass<ngraph::pass::ConvertOpSet1ToLegacy>();
// Use pass config to disable certain passes we dont need
auto pass_config = manager.get_pass_config();
// Disable because after HSwish decomposition, we look for Relu->Minimum group
// to merge into clamp if possible. Enabling this turns Minimum to Maximum with Mults
pass_config->disable<ngraph::pass::ConvertMinimum>();
// Dont need Interpolate -> resample transformation because we support Interpolate
pass_config->disable<ngraph::pass::ConvertInterpolateToInterpOrResampleMatcher>();
// Disabled because it may create a reshape that CoreDLA doesn't support
pass_config->disable<ngraph::pass::TransposeToReshape>();
manager.run_passes(ngraph_function);
Error is when building shared library (static is ok):
ngraph_transformations.cpp.obj : error LNK2019: unresolved external symbol "public: static struct ngraph::DiscreteTypeInfo const ngraph::pass::ConvertOpSet1ToLegacy::type_info" (?type_info@ConvertOpSet1ToLegacy@pass@ngraph@@2UDiscreteTypeInfo@3@B) referenced in function "public: void __cdecl ngraph::pass::PassConfig::disable<class ngraph::pass::ConvertOpSet1ToLegacy>(void)" (??$disable@VConvertOpSet1ToLegacy@pass@ngraph@@@PassConfig@pass@ngraph@@QEAAXXZ)
ngraph_transformations.cpp.obj : error LNK2019: unresolved external symbol "public: static struct ngraph::DiscreteTypeInfo const ngraph::pass::ConvertInterpolateToInterpOrResampleMatcher::type_info" (?type_info@ConvertInterpolateToInterpOrResampleMatcher@pass@ngraph@@2UDiscreteTypeInfo@3@B) referenced in function "public: void __cdecl ngraph::pass::PassConfig::disable<class ngraph::pass::ConvertInterpolateToInterpOrResampleMatcher>(void)" (??$disable@VConvertInterpolateToInterpOrResampleMatcher@pass@ngraph@@@PassConfig@pass@ngraph@@QEAAXXZ)
my_op_transformation.dll : fatal error LNK1120: 2 unresolved externals
What is the correct way of linking to inference_engine_legacy.dll.
One note: Linux version is fine, no issues linking to inference_engine_legacy.so .\
Thank you,
Domi
Hairul_Intel
Hi Domi,
Regarding the missing inference_engine_legacy.lib file from the install package, OpenVINO has removed the dependency on inference_engine_legacy since OpenVINO 2021.2 release. It is now linked by plugins directly.
Refer to the "Common Changes" subsection from "Inference Engine" section in "New and Changed in the Release 2" of Release Notes for Intel® Distribution of OpenVINO™ Toolkit 2021 for more information.
On another note, inference_engine_legacy.dll depends on tbb.dll as mentioned here. Follow Step 5 in the Build Steps guide to build the dependencies together with TBB binaries for OpenVINO in Windows.
Hairul
Domi
Hi Hairul,
Thank you for your response.
Just to be clear, from your answer I get is that if I want to create my own plugin on Windows I would need to build OpenVINO from source on Windows.
Is that right?
Thank you,
Domi
Hairul_Intel
Hi Domi,
It is possible to build your own plugin for Windows from source however, we do not have any tutorials on this particular subject.
As you’ve previously mentioned that there's no issue on Linux, we'd suggest you to add paths to the Threading Building Blocks (TBB) binaries used for the build to the %PATH% environment variable. By default, TBB binaries are downloaded by the CMake-based script to the <openvino_repo>/temp/tbb/bin folder.
Please do share with us the steps you used when building your plugin if you require further assistance.
Hairul
Hairul_Intel
Hi Domi,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Hairul
