OpenVINO model optimization - tensorflow not found.
Lejboelle__Aske
I'm trying to convert frozen tensorflow models to IR models using the OpenVINO model optimizer. I run the following command:
sudo python3 mo.py --input_model /home/asrl/openvino_models/mobilenet_v1_0.5_160_frozen.pb
but get the following error:
Detected not satisfied dependencies:
    tensorflow: not installed, required: 1.2.0
I have installed both tensorflow and tensorflow-gpu. I also ran the install_requirements scripts, but it did not help. I tried reinstalling OpenVINO, but without any luck. I can easily import tensorflow if I open a python3 terminal.
Anyone experienced similar issues?
System information:
Ubuntu 16.04
Tensorflow 1.12.0
Python 3.5.2
Aske
nikos1
Valued Contributor I
Hi Aske,
What  happens if your try without sudo? ( sudo can sometimes/always get you in a different OpenVino environemmt. )
for example
source  ~/intel/computer_vision_sdk/bin/setupvars.sh
python3 mo_tf.py --input_model  ...
cheers
nikos
nikos1
Hi Aske,
for example
cheers
nikos
Lejboelle__Aske
nikos wrote:
Hi Aske,
for example
cheers
nikos
It works. I, of course, just had to also specify an output dir in my home folder since the toolkit is installed in /opt/intel/.
