6597 Discussions
OpenVINO model zoo: camvid semantic segmentation
Letty
I would like to try and use some of the models available in the OpenVINO model zoo that use the Camvid dataset (e.g. icnet-camvid-ava-0001).
However I am confused by the description of the output, as it says that the classes used are 12 (https://github.com/openvinotoolkit/open_model_zoo/blob/master/models/intel/icnet-camvid-ava-0001/description/icnet-camvid-ava-0001.md), but the Camvid dataset on which it is based has 32 classes instead (http://mi.eng.cam.ac.uk/research/projects/VideoRec/CamVid/).
Is it possible to know which classes are the output of the icnet-camvid-ava-0001 model and in what order are the class IDs?
IntelSupport
Community Manager
Hi Letty,
The icnet-camvid-ava-0001 model is based on 12 classes version used for the training. Check out this research paper at section 3.2 and 4 on the CamVid and it classes available.
https://arxiv.org/pdf/1608.01745.pdf
Aznie
IntelSupport
Community Manager
Hi Letty,
Thanks for reaching out. We are investigating this and will get back to you at the earliest.
Aznie
IntelSupport
Community Manager
Hi Letty,
Aznie
Letty
Thanks a lot for the reply and for the link to the original paper, appreciate your help!
IntelSupport
Community Manager
Hi Letty,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
