OpenVINO with Intel Celeron J4125
m_salti
Does OpenVINO support inference on both the CPU and GPU for Intel Celeron J4125 ?
Munesh_Intel
Hi Salti,
The UHD Graphics 620 in the link you provided is an integrated GPU of Intel® Core™ i5-8350U Processor, which is a supported processor (8th Generation Intel® Core™ i5 Processor).
ODYSSEY - X86J4125800 has not been validated nor officially supported by OpenVINO.
Based on the specifications available in the link you shared, it does not meet the requirements (Intel® Celeron® Processor is not a supported processor).
Munesh
Munesh_Intel
Hi Salti,
Intel® Celeron® Processor J4125 (4M Cache, up to 2.70 GHz) is not supported by OpenVINO for inferencing using CPU or GPU.
The system requirements for Intel® Distribution of OpenVINO™ toolkit are available at System Requirements.
Munesh
m_salti
Hello Munesh,
Thanks for your answer.
Just to make sure there's no ambiguity; OpenVINO won't work on the integrated Intel® UHD Graphics 600 either?
Because this sample shows OpenVINO working on a UHD Graphics 620, although it's not listed in the system requirements you linked.
Specifically, I'm trying to know if OpenVINO will run on ODYSSEY - X86J4125800
Best Regards
Munesh_Intel
Hi Salti,
Munesh
Munesh_Intel
Hi Salti,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Munesh
