OpenVIVO Caffe model optimizer error
Nair__Dinesh
I recently installed OpenVIVO and the demo applications work well.
I get an error when trying to optimize the SSD_GoogleNetV2.caffemodel that is provided by Intel.
Steps followed:
1. Activate environment:
source /opt/intel/computer_vision_sdk_2018.1.249/deployment_tools/model_optimizer/install_prerequisites/../venv/bin/activate
2. Run model optimizer:
python3 mo.py --input_model ~/local/examples/intel_model/SSD_GoogleNetV2.caffemodel --input_proto ~/local/examples/intel_model/SSD_GoogleNetV2_Deploy.prototxt
The following error message is generated:
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  No module named 'networkx'
[ ERROR ]  Traceback (most recent call last):
  File "/opt/intel/computer_vision_sdk_2018.1.249/deployment_tools/model_optimizer/mo/main.py", line 222, in main
    return driver(argv)
  File "/opt/intel/computer_vision_sdk_2018.1.249/deployment_tools/model_optimizer/mo/main.py", line 98, in driver
    ret_code = check_requirements(framework=argv.framework)
  File "/opt/intel/computer_vision_sdk_2018.1.249/deployment_tools/model_optimizer/mo/utils/versions_checker.py", line 126, in check_requirements
    exec("import {}".format(modules[name] if name in modules else name))
  File "<string>", line 1, in <module>
ImportError: No module named 'networkx'
[ ERROR ]  ---------------- END OF BUG REPORT --------------
I've confirmed that networkx is installed.
Dinesh
Seunghyuk_P_Intel
Hi Nair Dinesh,
I'm not sure you did install prerequisites for caffemodel conversion but,
Can you try this?
1. Model optimizer prerequisites installation for caffe model
	$ sudo apt-get -y install python3-pip virtualenv cmake libpng12-dev libcairo2-dev libpango1.0-dev libglib2.0-dev libgtk2.0-dev libgstreamer0.10-dev libswscale-dev libavcodec-dev libavformat-dev python3-yaml
	$ cd /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/install_prerequisites
	$ sudo ./install_prerequisites.sh
	$ source /opt/intel/computer_vision_sdk/bin/setupvars.sh
	$ source ./venv/bin/activate
2. Model conversion
	// IR files, FP32 version, will be created in ~/Desktop/IR/FP32
	$ python3 ./mo.py --input_model ~/local/examples/intel_model/SSD_GoogleNetV2.caffemodel --output_dir ~/Desktop/IR
