6605 Discussions
OpenVX sample program crashed with illegal instruction
md_danish_a_
I have installed Intel Computer Vision SDK, to use ModelOptimizer with caffe from here. Installation was successful and using ModelOptimizer, OpenVX code was generated along with normalized weights. From the generated code main.c was compiled successfully along with its dependencies. When i am running the generated binary its showing illegal instruction.
<code>Program received signal SIGILL, Illegal instruction.
0x00007fffee0d3cbc in Xbyak::Operand::Operand(int, Xbyak::Operand::Kind, int, bool) ()
   from /home/vehiscan/intel/computer_vision_sdk_2017.0.113/openvx/lib/libmkldnn.so.0
Missing separate debuginfos, use: debuginfo-install glibc-2.17-106.el7_2.4.x86_64 libgcc-4.8.5-4.el7.x86_64 libstdc++-4.8.5-4.el7.x86_64
(gdb) bt
#0  0x00007fffee0d3cbc in Xbyak::Operand::Operand(int, Xbyak::Operand::Kind, int, bool) ()
#1  0x00007fffee0c72a2 in __sti__$E () from /home/vehiscan/intel/computer_vision_sdk_2017.0.113/openvx/lib/libmkldnn.so.0
#2  0x00007ffff7dea3a3 in _dl_init_internal () from /lib64/ld-linux-x86-64.so.2
#3  0x00007ffff7deeab6 in dl_open_worker () from /lib64/ld-linux-x86-64.so.2
#4  0x00007ffff7dea1b4 in _dl_catch_error () from /lib64/ld-linux-x86-64.so.2
#5  0x00007ffff7dee1ab in _dl_open () from /lib64/ld-linux-x86-64.so.2
#6  0x00007fffef3b402b in dlopen_doit () from /lib64/libdl.so.2
#7  0x00007ffff7dea1b4 in _dl_catch_error () from /lib64/ld-linux-x86-64.so.2
#8  0x00007fffef3b462d in _dlerror_run () from /lib64/libdl.so.2
#9  0x00007fffef3b40c1 in dlopen@@GLIBC_2.2.5 () from /lib64/libdl.so.2
#10 0x00007ffff79b7290 in vxLoadModule(char*) () from /home/vehiscan/intel/computer_vision_sdk_2017.0.113/openvx/lib/libiap_openvx.so.1.0
#11 0x00007ffff79c3fde in vxLoadTarget(_vx_context*, char*) () from /home/vehiscan/intel/computer_vision_sdk_2017.0.113/openvx/lib/libiap_openvx.so.1.0
#12 0x00007ffff794fb51 in vxCreateContext () from /home/vehiscan/intel/computer_vision_sdk_2017.0.113/openvx/lib/libiap_openvx.so.1.0
#13 0x0000000000401a26 in main (argc=1, argv=0x7fffffffe228) at main.c:44</code>
Below is my machine configuration:-
OS : CentOS-7.2
Processor : Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
Graphics : Intel® HD Graphics 4000
Stav_S_Intel
Did you install all prerequisites from this guide- https://software.intel.com/en-us/cvsdk-quickstartguide-installing-intel-computer-vision-sdk
Stav
md_danish_a_
Hi Stav S
Thanks for the response, My machine is Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz, which is i7-3rd generation core processor with Intel® HD Graphics 4000. And in the link you have shared, Its mentioned that supported and validated platforms are Intel 6th generation machines. Is it possible to use model optimizer on this machine, using any older SDK revisions.
Like I was able to use Media Server SDK on this Machine using R2 version, other versions were not compatible with this machine.
Danish
Stav_S_Intel
Hi Danish,
I'm afraid CV SDK is a newer product and there for there is not version supporting 3rd generation core processors.
Stav
