6589 Discussions
OpenVino 2022.1.0 does not detect VPU(MYRIAD): Configuration script errors.
Anzhela_G
I am having problems with configurations for Intel Vision Accelerator design with Intel Movidius VPU.
I did all the steps mentioned in the documentation:  https://docs.openvino.ai/latest/openvino_docs_install_guides_installing_openvino_ivad_vpu.html#vpu-guide
After running the configuration script it crashes with ./setup.sh install myd_vsc fail message and make errors.
I also tried to install the drivers again with running the setup.sh.
I didn't find anything in the Installation and Configuration issues section in documentation which could solve my problem.
After running ./hello_query_device script it shows me GNA, GPU, CPU, HDDL besides MYRIAD-X.
Could you answer what is the matter, please. I am attaching screenshots of all the outputs after running the scripts.
Regards.
Iffa_Intel
there might be conflicts between HDDL and MYRIAD plugin.
Try to reboot the host system and run with the MYRIAD Plugin or Kill the HDDL Plugin backend service (hddldaemon) and reset all Intel® Movidius™ VPUs before running an application that uses the MYRIAD Plugin:
kill -9 $(pidof hddldaemon autoboot)
pidof hddldaemon autoboot # Make sure none of them is alive
source /opt/intel/openvino_2022/setupvars.sh
${HDDL_INSTALL_DIR}/bin/bsl_reset
You may refer here.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
