6577 Discussions
[OpenVino C API] inference engine error while reading network
muleymakarand
Hi
I have converted my ML model using a model optimizer. My project is developed in C language and my model will be part of this project. I am trying to load the model using openvino C API.
Below are my project details
Development Environment - Visual Studio 2019
OpenVino Version - 2021 version 3
I am following hello_classification example step by step
Below is my code
int main(int argc, char** argv) {
// ------------------------------ Parsing and validation of input args ---------------------------------
if (argc != 4) {
printf("Usage : ./hello_classification <path_to_model> <path_to_image> <device_name>\n");
return EXIT_FAILURE;
const char* input_model = argv[1];
const char* input_image_path = argv[2];
const char* device_name = argv[3];
ie_core_t* core = NULL;
ie_network_t* network = NULL;
ie_executable_network_t* exe_network = NULL;
ie_infer_request_t* infer_request = NULL;
char* input_name = NULL, * output_name = NULL;
ie_blob_t* imgBlob = NULL, * output_blob = NULL;
// --------------------------- 1. Load inference engine instance -------------------------------------
IEStatusCode status = ie_core_create("", &core);
if (status != OK) {
printf("Failed to create");
return -1;
// 2. Read a model in OpenVINO Intermediate Representation (.xml and .bin files) or ONNX (.onnx file) format
status = ie_core_read_network(core, "saved_model.xml", "saved_model.bin", &network);
if (status != OK)
printf("Failed to read network");
goto err;
err:
if (core)
ie_core_free(&core);
if (network)
ie_network_free(&network);
if (input_name)
ie_network_name_free(&input_name);
if (output_name)
ie_network_name_free(&output_name);
if (exe_network)
ie_exec_network_free(&exe_network);
if (infer_request)
ie_infer_request_free(&infer_request);
if (imgBlob)
ie_blob_free(&imgBlob);
if (output_blob)
ie_blob_free(&output_blob);
I am facing error on highlighted line. I am trying to use ie_core_read_network() and both saved_model.bin and saved_model.xml are in same  place as .exe
When i call this function, i get status as UNEXPECTED
Am  i missing something here?
Iffa_Intel
That issue is related with MKLDNN plugin which usually happens if you didn't setup your environment properly (OpenVINO environment on your system).
Make sure you had done the steps as in here: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
Plus, make sure you had run the setupvars from your Visual Studio terminal before running anything inthe OpenVINO package.
You can also implement a script to auto run this in windows (Linux the setupvars should be set up to run permanently as in documentation shows)
My attachment is the example for that purpose.
Iffa_Intel
OpenVINO samples usually rely on multiple libraries that need to be properly linked.
Your cmake file needs to have all the required settings for the build too.
The setupvars initialization is also crucial.
Can you share your error snippets instead?
"i get status as UNEXPECTED" is not enough detail.
Sincerely,
Iffa
muleymakarand
Hi Iffa,
Thanks for your reply. PFA error snippets.
I am able to create .exe file.
when I run the program I get on an error on  line
status = ie_core_read_network(core, input_model, NULL, &network);
status should be "OK" but I am getting status as "UNEXPECTED"
Iam using following params
1) core is created using plugins.xml on line
     ie_core_create("plugins.xml", &core);
2) for input_model I am giving path of model xml file
3) for model weight parameter, i have tried giving NULL as well as .bin file path both
4) network is pointer for ie_network_t
If you need any details let me know.
Iffa_Intel
It seems that something is incomplete in your custom code.
Please help to follow this guideline especially when you are customing the Inference Engine API: https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_Deep_Learning_Inference_Engine_DevGuide.html
and this is the correct way of integrating your custom app with OpenVINO inference Engine:
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_Integrate_with_customer_application_new_API.html
muleymakarand
Hi Iffa,
Thanks for your quick response and these links, which have helped me proceed further. I was missing a couple of DLL's after including them I could read_network
Now I am having an error at the following function call
status = ie_network_get_input_name(network, 0, &input_name);
if (status != OK)
printf("\n not able to get network input name");
//goto err;
printf("\n Got input");
I have attached the error screenshot and my sample code.
Iffa_Intel
muleymakarand
Hi Iifa,
Thanks for the quick reply. I rechecked my setup and it was correct. The problem was, I was running setupvars.bat separately and not in Visual Studio terminal. After your advice, I am running setupvars.bat in the Visual Studio terminal, and it solved my MKLDNN issue. Thanks a lot.
Now I am trying to do inference.
Unlike the Hello_classification example in samples (which uses an image as data for inference), my example has time-series data.
My input is 12*25 matrix which needs to be given to every inference step and output is 1*25. (i am trying to predict output at timestamp T+12 based on input from timestamp T0 to T11. It has 25 features at every timestamp.
I understand that I need to create a blob (Based on the Hello Classification example), but I am not understanding how to do it.
Can you guide me on this?
Iffa_Intel
If you look at the previous documentation that I gave you before, it has explanation regarding blob:
This also contains the blob function explanation: https://docs.openvinotoolkit.org/latest/ie_c_api/group__Blob.html
Sincerely,
Iffa
muleymakarand
Hi Iffa,
Sorry for the late reply, I was on leave.
I have gone through these links, and it has helped me in the creation of the blob.
I am trying to invoke
status = ie_infer_request_set_blob(infer_request, input_name, imgBlob);
but I am getting status as -1 (General Error)
From my side, I have tried setting various precision values, making input resizable (In my case network IP is fixed and i won't be resizing it, still I checked with resizing also)
I have ensured that my inputs to the function are not null.
Any idea what may be causing this error?
PFA my code and my error screenshot
Iffa_Intel
Unfortunately, there is no specific documentation that explains in-depth the Error -1 (General Error).
However, the list of error for IEStatusCode can be obtained in this link: openvino/api_overview.md at 6a16b70e0ef7fba37052a2b7b3ddb63e8fc9b32e · openvinotoolkit/openvino (github.com)
​  OK = 0,
  GENERAL_ERROR = -1,
​  NOT_IMPLEMENTED = -2,
​  NETWORK_NOT_LOADED = -3,
​  PARAMETER_MISMATCH = -4,
​  NOT_FOUND = -5,
​  OUT_OF_BOUNDS = -6,
​  /* \* @brief exception not of std::exception derived type was thrown ​   */
​  UNEXPECTED = -7,
​  REQUEST_BUSY = -8,
​  RESULT_NOT_READY = -9,
​  NOT_ALLOCATED = -10,
​  INFER_NOT_STARTED = -11,
​  NETWORK_NOT_READ = -12
The error might comes from ie_infer_request_set_blob function itself - the format used might be wrong.
These methods are suggested (written in the documentation)
  • IEStatusCode ie_infer_request_set_blob(ie_infer_request_t *infer_request, ie_blob_t *blob)
    • Description: Sets the blob in a inference request.
  • Parameters:
    • infer_request : A pointer to ie_infer_request_t instance.
    • blob : A pointer to ie_blob_t instance.
  • Return value: Status code of the operation: OK(0) for success.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
muleymakarand
Greetings,
Thanks to your continuous support, i am able to do inference using OpenVino C
Makarand Muley
