OpenVino: Configure the Model Optimizer
gomes__antonio
I'm trying to install OpenVino in Windows 10. I install all dependencies correctly and without error.
In Model Optimizer configuration when I run the install_prerequisites.bat give me this error and i can't configure the model optimizer:
Can someone help please?? Thanks
 Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'Uma ligação existente foi forçada a fechar pelo anfitrião remoto', None, 10054, None))': /simple/tensorflow/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'Uma ligação existente foi forçada a fechar pelo anfitrião remoto', None, 10054, None))': /simple/tensorflow/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'Uma ligação existente foi forçada a fechar pelo anfitrião remoto', None, 10054, None))': /simple/tensorflow/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'Uma ligação existente foi forçada a fechar pelo anfitrião remoto', None, 10054, None))': /simple/tensorflow/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'Uma ligação existente foi forçada a fechar pelo anfitrião remoto', None, 10054, None))': /simple/tensorflow/
  Could not find a version that satisfies the requirement tensorflow>=1.2.0 (from -r ..\requirements.txt (line 1)) (from versions: )
No matching distribution found for tensorflow>=1.2.0 (from -r ..\requirements.txt (line 1))
