OpenVino Demo Verification not successful
Hernandez__Sebastian
I've been trying to run the sample demos for successful installation of openVino, but I keep getting the following error:
I've also looked into the folder and when I head to "Intel\OpenVino *Only the inferencing folder comes up and the openVino_models folder doesn't appear. See below
Errors in BOLD
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino
Python 3.7.4
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (5.1.2)
Requirement already satisfied: requests in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (2.18.4)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (from requests) (2019.6.16)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (from requests) (3.0.4)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (from requests) (2.6)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\sebastian hernandez\appdata\roaming\python\python37\site-packages (from requests) (1.22)
You are using pip version 19.0.3, however version 19.2.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.
Download public squeezenet1.1 model
Models have been loaded previously. Skip loading model step.
Model path: C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\models\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.prototxt
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\tools\model_downloader\downloader.py" --name squeezenet1.1 --output_dir C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\models\FP16 --cache_dir C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\cache
error: unrecognized arguments: Hernandez\Documents\Intel\OpenVINO\openvino_models\models\FP16 Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\cache
usage: downloader.py [-h] [-c CONFIG.YML] [--name PAT[,PAT...]]
                     [--list FILE.LST] [--all] [--print_all] [-o DIR]
                     [--cache_dir DIR] [--num_attempts N]
optional arguments:
  -h, --help            show this help message and exit
  -c CONFIG.YML, --config CONFIG.YML
                        path to YML configuration file
  --name PAT[,PAT...]   download only topologies whose names match at least
                        one of the specified patterns
  --list FILE.LST       download only topologies whose names match at least
                        one of the patterns in the specified file
  --all                 download all topologies from the configuration file
  --print_all           print all available topologies
  -o DIR, --output_dir DIR
                        path where to save topologies
  --cache_dir DIR       directory to use as a cache for downloaded files
  --num_attempts N      attempt each download up to N times
list_topologies.yml - default configuration file
squeezenet1.1 model downloading completed
Waiting for 0 seconds, press a key to continue ...
Target folder C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
"vswhere tool is not found"
Creating Visual Studio 14 2015 x64 files in C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version  to target Windows 10.0.18362.
-- The C compiler identification is MSVC 19.0.24215.1
-- The CXX compiler identification is MSVC 19.0.24215.1
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check size of __int32
-- Check size of __int32 - done
-- Found InferenceEngine: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/inference_engine.lib (Required is at least version "2.0")
-- Performing Test HAVE_CPUID_INFO
-- Performing Test HAVE_CPUID_INFO - Success
-- Host CPU features:
--   3DNOW not supported
--   3DNOWEXT not supported
--   ABM not supported
--   ADX supported
--   AES supported
--   AVX supported
--   AVX2 supported
--   AVX512CD not supported
--   AVX512F not supported
--   AVX512ER not supported
--   AVX512PF not supported
--   BMI1 supported
--   BMI2 supported
--   CLFSH supported
--   CMPXCHG16B supported
--   CX8 supported
--   ERMS supported
--   F16C supported
--   FMA supported
--   FSGSBASE supported
--   FXSR supported
--   HLE supported
--   INVPCID supported
--   LAHF supported
--   LZCNT supported
--   MMX supported
--   MMXEXT not supported
--   MONITOR supported
--   MOVBE supported
--   MSR supported
--   OSXSAVE supported
--   PCLMULQDQ supported
--   POPCNT supported
--   PREFETCHWT1 not supported
--   RDRAND supported
--   RDSEED supported
--   RDTSCP supported
--   RTM supported
--   SEP supported
--   SHA not supported
--   SSE supported
--   SSE2 supported
--   SSE3 supported
--   SSE4.1 supported
--   SSE4.2 supported
--   SSE4a not supported
--   SSSE3 supported
--   SYSCALL supported
--   TBM not supported
--   XOP not supported
--   XSAVE supported
-- TBB include: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/external/tbb/include
-- TBB Release lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/tbb.lib
-- TBB Debug lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Debug/tbb_debug.lib
-- Looking for pthread.h
-- Looking for pthread.h - not found
-- Found Threads: TRUE
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Sebastian Hernandez/Documents/Intel/OpenVINO/inference_engine_samples_build
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
C:\Program Files (x86)\MSBuild\14.0\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release /t:classification_sample_async /clp:ErrorsOnly /m
Microsoft (R) Build Engine version 14.0.25420.1
Copyright (C) Microsoft Corporation. All rights reserved.
###############|| Run Inference Engine classification sample ||###############
The system cannot find the path specified.
        0 file(s) copied.
classification_sample_async.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png" -m "C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.xml" -d MYRIAD
[ INFO ] InferenceEngine:
        API version ............ 2.0
        Build .................. 27579
        Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png
[ INFO ] Creating Inference Engine
        MYRIAD
        myriadPlugin version ......... 2.0
        Build ........... 27579
[ INFO ] Loading network files
[ ERROR ] Error loading xmlfile: C:\Users\Sebastian Hernandez\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.xml, File was not found at line: 1 pos: 0
Error
P.S.
All dependencies have been installed.
CPU i9 9900kf
Windows 10 latest update
Shubha_R_Intel
Dear Hernandez, Sebastian
The space in your User name is probably why:
Other customers have suffered this problem also. Can you kindly create another User this time without a space in the UserID ? For instance SebastianHernandez or Sebastian_Hernandez would work.
Shubha
