OpenVino Model Optimizer-Shape [-1 -1 -1 1] is not fully defined for output 0 of "image"
rachel_r_Intel
I am trying to help convert trained tensorflow model hfnet, I have no idea about more information about this model(I don't know the --input_shape parameter).this is the folder structure.
├── hfnet
│   ├── checkpoint
│   ├── config.yaml
│   ├── events.out.tfevents.1541966416.lo-s4-033
│   ├── log
│   ├── model.ckpt-83096.data-00000-of-00001
│   └── model.ckpt-83096.index
└── saved_models
    └── hfnet
        ├── saved_model.pb
        └── variables
            ├── variables.data-00000-of-00001
            └── variables.index
command:
python3 mo_tf.py --saved_model_dir /home/intel/hfnet/saved_models/hfnet/
I get the following error:
Common parameters:
	- Path to the Input Model: 	None
	- Path for generated IR: 	/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/.
	- IR output name: 	saved_model
	- Log level: 	ERROR
	- Batch: 	Not specified, inherited from the model
	- Input layers: 	Not specified, inherited from the model
	- Output layers: 	Not specified, inherited from the model
	- Input shapes: 	Not specified, inherited from the model
	- Mean values: 	Not specified
	- Scale values: 	Not specified
	- Scale factor: 	Not specified
	- Precision of IR: 	FP32
	- Enable fusing: 	True
	- Enable grouped convolutions fusing: 	True
	- Move mean values to preprocess section: 	False
	- Reverse input channels: 	False
TensorFlow specific parameters:
	- Input model in text protobuf format: 	False
	- Path to model dump for TensorBoard: 	None
	- List of shared libraries with TensorFlow custom layers implementation: 	None
	- Update the configuration file with input/output node names: 	None
	- Use configuration file used to generate the model with Object Detection API: 	None
	- Operations to offload: 	None
	- Patterns to offload: 	None
	- Use the config file: 	None
Model Optimizer version: 	2019.3.0-408-gac8584cb7
[ ERROR ]  Shape [-1 -1 -1  1] is not fully defined for output 0 of "image". Use --input_shape with positive integers to override model input shapes.
[ ERROR ]  Cannot infer shapes or values for node "image".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "image".
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #40.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Parameter.__init__.<locals>.<lambda> at 0x7fc05e765598>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
Stopped shape/value propagation at "image" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Not all output shapes were inferred or fully defined for node "image".
Any help?Thanks
Monique_J_Intel
Hi Rachel,
You can analyze your model using summarize graph tool and that should be able to tell you information about your inputs and outputs. The python tool is in /opt/intel/openvino/deployment_tools/model_optimizer/mo/utils/. To understand how to run it type summarize_graph.py -h.
Also taking a look at the github and knowing Tensorflow extensively your input tensor is in the form of [Batch,Height,Width,Channels] with color channels being 1.
So if you know that you'll only be processing 1 image at a time and you know the height and width of the test images you can fill this in for example  if your image resolution is 300x300 then try
python3 mo_tf.py --saved_model_dir /home/intel/hfnet/saved_models/hfnet/ --input_shape [1,300,300,1]
Let me know if this helps.
Kind Regards,
Monique Jones
daisyyang
Hi Monique,
Thanks for sharing your idea. I got the same error as Rachel, but I'm trying to convert an onnx model. Looks like summarize_graph tool is only for TensorFlow model? Do you know is there any tool can get the input shape of an onnx model?
Daisy
