OpenVino accuracy checker - logging
Aurjay
Can someone shed some light on how to export the results of the accuracy checker in Openvino from Windows command line to a .txt file or similar. Seeing the accuracy just on the cmd is not effective.
Relevant Links or Windows Cmd would be helpful.
IntelSupport
Community Manager
Hi Aurjay,
Thanks for reaching out.
The output can be exported into the .txt file by using the --log_file arguments in your accuracy_check command.
Command used:
accuracy_check -c sample/sample_config.yml -m data/test_models -s sample --log_file test.txt
Aznie
IntelSupport
Community Manager
Hi Aurjay,
Command used:
Aznie
IntelSupport
Community Manager
Hi Aurjay,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
