6584 Discussions
OpenVino development tools not getting installed, throwing , No module named 'distutils'.
Amaan1232344234
I am using python version - 3.12.1 for windows, I am trying to install openvino Development tools using this command - pip install openvino-dev , also I have installed systemtools, despite installing it I am getting this error.
Defaulting to user installation because normal site-packages is not writeable
Collecting openvino-dev
Using cached openvino_dev-2023.2.0-13089-py3-none-any.whl.metadata (17 kB)
Collecting addict>=2.4.0 (from openvino-dev)
Using cached addict-2.4.0-py3-none-any.whl (3.8 kB)
Collecting defusedxml>=0.7.1 (from openvino-dev)
Using cached defusedxml-0.7.1-py2.py3-none-any.whl (25 kB)
Collecting jstyleson>=0.0.2 (from openvino-dev)
Using cached jstyleson-0.0.2.tar.gz (2.0 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Collecting networkx<=3.1 (from openvino-dev)
Using cached networkx-3.1-py3-none-any.whl (2.1 MB)
Requirement already satisfied: numpy>=1.16.6 in c:\users\amaan\appdata\roaming\python\python312\site-packages (from openvino-dev) (1.26.3)
Collecting opencv-python (from openvino-dev)
Using cached opencv_python-4.9.0.80-cp37-abi3-win_amd64.whl.metadata (20 kB)
Collecting openvino-telemetry>=2022.1.0 (from openvino-dev)
Using cached openvino_telemetry-2023.2.1-py3-none-any.whl.metadata (2.3 kB)
Collecting pillow>=8.1.2 (from openvino-dev)
Using cached pillow-10.2.0-cp312-cp312-win_amd64.whl.metadata (9.9 kB)
Collecting pyyaml>=5.4.1 (from openvino-dev)
Using cached PyYAML-6.0.1-cp312-cp312-win_amd64.whl.metadata (2.1 kB)
Requirement already satisfied: requests>=2.25.1 in c:\users\amaan\appdata\roaming\python\python312\site-packages (from openvino-dev) (2.31.0)
Collecting scipy>=1.8 (from openvino-dev)
Using cached scipy-1.11.4-cp312-cp312-win_amd64.whl.metadata (60 kB)
Collecting texttable>=1.6.3 (from openvino-dev)
Using cached texttable-1.7.0-py2.py3-none-any.whl.metadata (9.8 kB)
Collecting tqdm>=4.54.1 (from openvino-dev)
Using cached tqdm-4.66.1-py3-none-any.whl.metadata (57 kB)
INFO: pip is looking at multiple versions of openvino-dev to determine which version is compatible with other requirements. This could take a while.
Using cached openvino_dev-2023.1.0-12185-py3-none-any.whl.metadata (17 kB)
Using cached openvino_dev-2023.0.2-11065-py3-none-any.whl.metadata (17 kB)
Collecting networkx<=2.8.8 (from openvino-dev)
Using cached networkx-2.8.8-py3-none-any.whl (2.0 MB)
Using cached openvino_dev-2023.0.1-11005-py3-none-any.whl.metadata (17 kB)
Using cached openvino_dev-2023.0.0-10927-py3-none-any.whl.metadata (17 kB)
Using cached openvino_dev-2022.3.1-9227-py3-none-any.whl.metadata (18 kB)
Collecting numpy<1.25.0,>=1.16.6 (from openvino-dev)
Using cached numpy-1.24.4.tar.gz (10.9 MB)
ERROR: Exception:
Traceback (most recent call last):
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\cli\base_command.py", line 180, in exc_logging_wrapper
status = run_func(*args)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\cli\req_command.py", line 245, in wrapper
return func(self, options, args)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\commands\install.py", line 377, in run
requirement_set = resolver.resolve(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\resolver.py", line 95, in resolve
result = self._result = resolver.resolve(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\resolvers.py", line 546, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\resolvers.py", line 427, in resolve
failure_causes = self._attempt_to_pin_criterion(name)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\resolvers.py", line 239, in _attempt_to_pin_criterion
criteria = self._get_updated_criteria(candidate)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\resolvers.py", line 230, in _get_updated_criteria
self._add_to_criteria(criteria, requirement, parent=candidate)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\resolvers.py", line 173, in _add_to_criteria
if not criterion.candidates:
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\resolvelib\structs.py", line 156, in bool
return bool(self._sequence)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\found_candidates.py", line 155, in bool
return any(self)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\found_candidates.py", line 143, in
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\found_candidates.py", line 47, in _iter_built
candidate = func()
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\factory.py", line 182, in _make_candidate_from_link
base: Optional[BaseCandidate] = self._make_base_candidate_from_link(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\factory.py", line 228, in _make_base_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\candidates.py", line 293, in init
super().init(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\candidates.py", line 156, in init
self.dist = self._prepare()
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\candidates.py", line 225, in _prepare
dist = self._prepare_distribution()
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\resolution\resolvelib\candidates.py", line 304, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\operations\prepare.py", line 525, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\operations\prepare.py", line 640, in _prepare_linked_requirement
dist = _get_prepared_distribution(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\operations\prepare.py", line 71, in _get_prepared_distribution
abstract_dist.prepare_distribution_metadata(
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\distributions\sdist.py", line 54, in prepare_distribution_metadata
self._install_build_reqs(finder)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\distributions\sdist.py", line 124, in _install_build_reqs
build_reqs = self._get_build_requires_wheel()
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\distributions\sdist.py", line 101, in _get_build_requires_wheel
return backend.get_requires_for_build_wheel()
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_internal\utils\misc.py", line 751, in get_requires_for_build_wheel
return super().get_requires_for_build_wheel(config_settings=cs)
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\pyproject_hooks_impl.py", line 166, in get_requires_for_build_wheel
return self._call_hook('get_requires_for_build_wheel', {
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\pyproject_hooks_impl.py", line 321, in _call_hook
raise BackendUnavailable(data.get('traceback', ''))
pip._vendor.pyproject_hooks._impl.BackendUnavailable: Traceback (most recent call last):
File "C:\Users\amaan\AppData\Roaming\Python\Python312\site-packages\pip_vendor\pyproject_hooks_in_process_in_process.py", line 77, in build_backend
obj = import_module(mod_path)
File "C:\Program Files\Python312\Lib\importlib_init
.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "", line 1387, in _gcd_import
File "", line 1360, in _find_and_load
File "", line 1310, in _find_and_load_unlocked
File "", line 488, in _call_with_frames_removed
File "", line 1331, in _find_and_load_unlocked
File "", line 935, in _load_unlocked
File "", line 994, in exec_module
File "", line 488, in call_with_frames_removed
File "C:\Users\amaan\AppData\Local\Temp\pip-build-env-aug7ye8l\overlay\Lib\site-packages\setuptools_init
.py", line 10, in
import distutils.core
ModuleNotFoundError: No module named 'distutils'
Aznie_Intel
Hi Amaan1232344234,
Thanks for reaching out.
This error happens because your Python version is not a compatible version with OpenVINO 2023.2. Only Python 3.8 - 3.11 is the supported version for OpenVINO. You may refer to this Install OpenVINO™ Development Tools and Operating systems and developer environment.
Aznie
Aznie_Intel
Hi Amaan1232344234,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
