OpenVino failed to create engine -d GPU
estefan__mike
I have been trying to run OpenVino on the GPU using -d command but i keep getting this error
API version ............ 1.6
    Build .................. 23780
    Description ....... clDNNPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is forced to  1
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the GPU plugin
[ ERROR ] failed to create engine: clGetPlatformIDs error -1001
Error on or near line 228; exiting with status 1
My system is Intel Hades Canyon 8th Gen NUC with Overclocked i7 Processor - NUC8i7HVK specs is:
Intel® Core™ i7-8705G Processor
Radeon™ RX Vega M GL graphics (8M Cache, up to 4.10 GHz)
100W TDP
2x Gigabit Ethernet, 802.11ac and Bluetooth 4.2
DDR4-2400+ 1.2V SO-DIMM RAM - 32GB max
2x Mini-DP 1.2, 2x Thunderbolt 3, F+R HDMI 2.0a display
Intel® Virtualization Technology for Directed I/O (VT-d)
Intel® Rapid Storage Technology
Intel® HD Audio Technology
I have tried everything including
If you use 8th Generation Intel® Core™ processor, you will need to add:
   i915.alpha_support=1
   to the 4.14 kernel command line in the grub config file, in order to enable OpenCL functionality for this platform.
I updated my kernel and added i915.alpha_support=1 to my grub but still same problem
Shubha_R_Intel
Dear estefan, mike,
If your GPU is supported then you shouldn't have to do any custom hacking like you did. Your GPU Radeon™ RX Vega M GL graphics (8M Cache, up to 4.10 GHz) is not supported by OpenVino though.
Only Intel GPUs are supported and Radeon is AMD.
Hope it helps.
Shubha
Shailesh_P_Intel
Hello OpenVino team,
Have recently bought  Intel Hades Canyon 8th Gen NUC with Overclocked i7 Processor - NUC8i7HVK specs is:
While running OpenVino conatiner for GPU:
_[35mopenvino_face_detect-gpu       |_[0m [ INFO ] Loading network files for Face Detection
_[35mopenvino_face_detect-gpu       |_[0m [ INFO ] Batch size is set to 1
_[35mopenvino_face_detect-gpu       |_[0m [ INFO ] Checking Face Detection network inputs
_[35mopenvino_face_detect-gpu       |_[0m [ INFO ] Checking Face Detection network outputs
_[35mopenvino_face_detect-gpu       |_[0m [ INFO ] Loading Face Detection model to the GPU plugin
_[35mopenvino_face_detect-gpu       |_[0m [ ERROR ] failed to create engine: clGetPlatformIDs error -1001
_[35mopenvino_face_detect-gpu       |_[0m + sleep 1
_[35mopenvino_face_detect-gpu       |_[0m + true
the error: failed to create enginer
Please do let me know if there is anything i can do to make it work ?
nikos1
Valued Contributor I
Hello Pandey, Shailesh
To get this to work first you need to reconfigure your system to recognize the Intel® HD Graphics 630 that is inside your Intel® Core™ i7-8705G Processor
In some cases this may not be possible.
Try BIOS settings, connecting a display to the VGA/HDMI/DP of the Intel GPU or other OS settings.
Eventually you need to run
clinfo
and display the Intel GPU as an OpenCL GPU device.
Cheers,
nikos
